ls/vtec and Turbonetics T3 ok?
b18a bottom, JE 9:1, eagle rods, in process of doing vtec swap 94 gsr and I have a T3 here and was wondering if I should get a bigger turbo like a T3/T4? It will be tuned at 10-12psi
Man U FTW
If the bottom end is built, there's no reason to have such low goals. Secondly, when you're grouping "T3/T4" that doesn't tell us anything because there is a lot of variation in that grouping.
What are your POWER goals and what is your budget??
Re: (Schister66)
how much boost do you believe this set up can handle? My goals will be as big as my wallet is. You say my goals should be higher what to you mean?
* B A N N E D *
Re: (EFz6er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFz6er »</TD></TR><TR><TD CLASS="quote">how much boost do you believe this set up can handle? My goals will be as big as my wallet is. You say my goals should be higher what to you mean?</TD></TR></TABLE>
he means if you're getting pistons and rods your set up should be able to withstand much more psi than 10-12 reliably providing a good tune...you're cutting yourself short...
Man U FTW
On a built LS/VTEC i would shoot for no less than about 385whp, but more realistically about 425whp. Its all dependent on your goals, but that's what i'd do..
Re: (Schister66)
i can make 400whp with that turbo/set up reliably, provided the tune is good?
Im also looking at mild p&p, skunk2 IM and should I get a bigger TB? Worth the gains? Thanks for the info all
Man U FTW
With the setup you listed, you should be able to run 400whp all day every day on a good tune. As for the intake manifold, dont waste your money on a Skunk2, spend the extra $$ and get an Edelbrock.
To answer your question about the TB, you should read this thread. Find my post about 3/4 down the page and then read from there on...
Re: (Schister66)
Thanks lots of good info there I should have this all done by early Feb.
How much boost can thiis set up handle safely....but still pushing her a bit?
I see you got the HP IM on your gsr...hows that?
i ♥ snails
Re: (mn_babyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mn_babyboy »</TD></TR><TR><TD CLASS="quote">I'm pretty sure your turbo will max out before you blow your motor. Pistons and rods can handle well over 450whp no problem.
Stock b18's can handle 10 psi </TD></TR></TABLE>
Man U FTW
Re: (EFz6er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFz6er »</TD></TR><TR><TD CLASS="quote">Thanks lots of good info there I should have this all done by early Feb. </TD></TR></TABLE>
As will mine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFz6er »</TD></TR><TR><TD CLASS="quote">How much POWER can thiis set up handle safely....but still pushing her a bit? </TD></TR></TABLE>
I would say that 400whp would be a good number to stay at. You're not going to risk sleeve failure at that power level, but you'll have enough get-up to have some fun
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFz6er »</TD></TR><TR><TD CLASS="quote">I see you got the HP IM on your gsr...hows that?</TD></TR></TABLE>
It works really well and flows great in the upper RPMs. I used to sell them through "MiamiDamian" who's now at TD AutoWorks. They're great manifolds, but ONLY for the GSR head.
As will mine
