Stock Ignition Enough?
Old Jan 11, 2008 | 09:12 AM
HybridEL's Avatar
Default Stock Ignition Enough?
Hey guys, I'm nearing completion on my project, and I'm trying to work out any of the little things that I may have forgotten about, and I was wondering if my stock ignition will be enough?
its an ls/tec that will be running on a S300, 780cc injectors, and between 15-20 psi, with a power goal of somewhere around 400+. All depends on what my tuner can come up with.
So my question is, will my stock ignition hold up? or should I upgrade to something like this
http://www.msdignition.com/ignition_4_6200.htm
along with the coil & dizzy.
And before I get flamed with the usual use the search comments, I did.. but all the came up was people selling stuff.
Thanks again
Old Jan 11, 2008 | 09:17 AM
Turbo-charged's Avatar
Default Re: Stock Ignition Enough? (HybridEL)
at those power levels stock should be fine, however if you upgrade to an M&W pro 10 you get to eliminate the ignitor in the distributor which eliminates a lot of possible problems down the road.
Old Jan 11, 2008 | 09:21 AM
HybridEL's Avatar
Default Re: Stock Ignition Enough? (Turbo-charged)
thanks for the quick reply. Would you mind posting a link for the pro 10?
I'm not too sure what that is.. thanks buddy
Old Jan 11, 2008 | 09:29 AM
http://www.t1raceparts.com/M_W...1.htm
Old Jan 11, 2008 | 09:48 AM
tony1's Avatar
On sale this month!
http://www.t1raceparts.com/T1_...t.htm
HybridEL's Avatar
cool, thanks man.
Old Jan 11, 2008 | 09:49 AM
mtber's Avatar
We have tuned several cars that make 400-500 whp on oem honda distributors with oem plug wires without issues. The key to not having ignition problems is making sure that your distributor assembly is maintained (cap/rotor/coil/icm etc).
The m&w units appear to work well if you want to upgrade the factory system
Old Jan 26, 2008 | 12:43 PM
rudebwoy's Avatar
Default Re: Stock Ignition Enough? (mtber)
my statement retracted! MSD sucks!1!!
my msd distributor failed the day before dyno tune while street tuning
the following day I made 440whp on 14 psi running rich with OEM IGNITION.
now my setup is changed and my goal is changed to 700+whp on OEM IGNITION.
I am a little worried it will not be enough but I will give it a try, if it don't work I will try AEM setup with a Crane coil
Modified by rudebwoy at 10:54 PM 5/24/2008
Old Jan 26, 2008 | 12:55 PM
rudebwoy's Avatar
burn MSD BURN!
good thing it was still under warranty summit refunded me
Modified by rudebwoy at 11:00 PM 5/24/2008
Old Jan 26, 2008 | 01:03 PM
moores55's Avatar
I ran the 6al on my boosted eg when i had it and it was like night and day. I could tell it was running hotter just b/c my rear bumper started to melt after the install, lol. then i had to put a dump pipe on my exhaust to fix it. Msd ftw.
Old Jan 26, 2008 | 01:33 PM
JDMs1eeper's Avatar
Default Re: Stock Ignition Enough? (moores55)
Ive never had good luck with MSD. On higher boost on every MSD setup ive used, i get spark blow out and ignition issues.
Ive had great success from just running a stock Distributor.up to 600hp
The unit Joe and Tony just linked you to is a top notch setup. Id spend the extra cash and go with that route if the OEM unit doesn't work for you.
Old Jan 26, 2008 | 01:41 PM
RCautoworks's Avatar
Default Re: Stock Ignition Enough? (JDMs1eeper)
I have heard, and encountered to many problems with msd units.
Old Jan 26, 2008 | 01:54 PM
92redhatch's Avatar
i run msd system with no issues (62-1bb turbo 84x89 setup)
Old Jan 26, 2008 | 02:38 PM
Schister66's Avatar
Man U FTW
Default Re: Stock Ignition Enough? (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">I have heard, and encountered to many problems with msd units. </TD></TR></TABLE>
I've never used any of their stuff, but i've heard enough bad stories to keep me from using them. I'd stick with stock ignition and whenever you have the money or make enough power to justify it, go with the ignition Tony has...
redline1219
Feb 12, 2011 11:21 AM
eg:R
Sep 15, 2009 06:27 AM
yaaj1320
Mar 10, 2007 11:35 PM
SiRkid
Dec 15, 2006 10:53 AM
SpeedMonkeyRacing
Mar 31, 2003 01:04 PM
