single turbo
Old Jan 2, 2008 | 04:49 PM
p3terson17's Avatar
Default single turbo
i got a stock single cam with an ebay turbo had a question what should i use 4 this setup
size injecters
how many pounds of boost that it will last me
can i keep everything stock like (fuel pump and etc .....)
i know ebay turbos are bad but i got good deal 4 it
my first setup
Old Jan 2, 2008 | 05:04 PM
TDogg Teg's Avatar
Default Re: single turbo (p3terson17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p3terson17 &raquo;</TD></TR><TR><TD CLASS="quote">i got a stock single cam with an ebay turbo had a question what should i use 4 this setup
size injecters
my first setup </TD></TR></TABLE>
First of all, dont set a psi goal. Set a horsepower goal. Psi doesnt break motors, horsepower does. Is this your daily driver?
As far as that ebay turbo, why did you buy it if you knew they were bad? Do a search with the red button at the top of your page on em. THEN get rid of it. If you want a good turbo, look here: https://honda-tech.com/zeroforum/49
A turbo project is NOT something to cut corners and cheap out on. As far as injectors, get you some DSM 450's (search again) and a Walbro 255, and you'll be fine. For more info, PM Adam (Shister66), or Mac (The Shodan) on turbos. Good luck.
Old Jan 2, 2008 | 05:05 PM
roachsboosted16's Avatar
new 450cc dsms, new fuel pump walboro 255lph, good management unit and good tuner.
jv88_dc2
Feb 4, 2012 08:23 PM
092eg6
Jan 3, 2010 05:42 PM
DeLucious
Aug 21, 2009 03:52 PM
xtrnl
Dec 2, 2007 11:59 AM
tshracing
Sep 23, 2006 03:07 PM
