Can anyone identify these injectors?
1 Post
There are no stickers on them. All they say is SIEMENS DGK and the other side says 3105 on 3 of the injectors and 3145 on the 4th injector. does anyone know what these are?
Mr. Badwrench
Re: Can anyone identify these injectors? (Crx Jimmy)
quick google on the 3105:
http://www.fiveomotorsport.com/Injector_MILLED.asp
83# lb/hr 850 cc/min
3145 = 750cc/min
it is possible that the flow has been matched.
get em bench tested.
3145 = 750cc/min
1 Post
Re: Can anyone identify these injectors? (TheShodan)
thanks for the info, does anyone know of a reputable company that would flow test them /and or match them? they dont seem to be very expensive injectors. Is it worth it if I want to use them?
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">thanks for the info, does anyone know of a reputable company that would flow test them /and or match them? they dont seem to be very expensive injectors. Is it worth it if I want to use them?</TD></TR></TABLE>
Like I said, they work fine. I've used them on over 12 different applications.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">I've used those 3105 in several different applications, including a nice street civic with a GT3567R. They are VERY reliable from my experience</TD></TR></TABLE>
theshodan says they're reliable..and he usually gives some pretty solid advice..
Mr. Badwrench
Re: Can anyone identify these injectors? (projectstacy)
i think the o.p. is going off of the fact that they are 2 different numbers with 2 different flow rates, assuming someone had them matched. not necessarilly saying the injectors are bad or not, just not matched.
the 2 munbers he gave, i saw 3x 850's and 1x 750.
rc should be able to clean and balance them.
bootlegtrader
10
09-19-2005 05:40 AM
