Exospeed ST2 cams LS-T
Old Jan 7, 2008 | 05:10 PM
roddy9's Avatar
Default Exospeed ST2 cams LS-T
Currently have LS turbo on my hatch running 11psi and I was wondering if anyone had these cams on there LS and are they worth getting. They are EXOSPEED STAGE 2 cams. PLease any advice or feedback is wonderful cause I want more POWER!!! so i can crank the boost.
Old Jan 7, 2008 | 05:22 PM
vietjdmboi's Avatar
from what i've read on evans-tuning. the crane cam ls turbo cams are very good compared to the crowers. might want to look into those.
Old Jan 8, 2008 | 07:46 PM
ExospeedAMcrx's Avatar
Default Re: Exospeed ST2 cams LS-T (roddy9)
Well to be honest with you. Just putting a cam in isnt going to make give it more power off the bat. to explain it simply, what an aftermarket cam does is let you gain more power by changing the time the intake and exhaust valves open up and how soon and how fast they open up. Just dropping them in wont give you the full potential of the cam. You still have to fine tune the cam with cam gears to find that sweet spot where your engine and the tune likes the cam to be.
So if youre looking to get a cam, be prepared to do cam adjustments to get the full potential. It will get you a bit more power than a stock cam would at the same boost. But dont expect huge gains, until you are really boosting high.
As far as our cams, we've seen gains of 30-40hp at 18psi with changing the cam and fine tuning.
Old Jan 8, 2008 | 08:05 PM
Joseph Davis's Avatar
Default Re: Exospeed ST2 cams LS-T (ExospeedAMcrx)
Uhm, these are LS cams we are talking about. I fail to see how a retarded child couldn't design cams that would manifest 30-40 whp in an otherwise stock naturally aspirated LS.
Old Jan 8, 2008 | 08:25 PM
Default Re: Exospeed ST2 cams LS-T (Joseph Davis)
LS cams. non-vtec. b18a/b.
I dont knwo what you are trying to get at. 40hp gain just by changing from stock cams I think is decent.
Aftermarket VTEC turbo cams gain about 100 or so in 30psi setups. 40hp at 18psi with mininal adjustments is a great gain.
Modified by ExospeedAMcrx at 9:36 PM 1/8/2008
Old Jan 8, 2008 | 08:36 PM
661rex89si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">Uhm, these are LS cams we are talking about. I fail to see how a retarded child couldn't design cams that would manifest 30-40 whp in an otherwise stock naturally aspirated LS.
are you serious rethink what you just said.
Old Jan 8, 2008 | 08:54 PM
Default Re: Exospeed ST2 cams LS-T (661rex89si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 661rex89si &raquo;</TD></TR><TR><TD CLASS="quote">are you serious rethink what you just said.</TD></TR></TABLE>
That stock LS cams suck?
hondacrx2
May 31, 2007 06:51 PM
DrewQ1
Mar 7, 2004 05:03 PM
DOHCon15s
May 12, 2003 01:36 PM
boosted hybrid
Dec 19, 2001 11:06 AM
