problem with down pipe please help
Old Jan 3, 2008 | 10:18 AM
pbzhb's Avatar
Default problem with down pipe please help
ok so i have mounted the downpipe however I cannot put in one bolt, the bolt on the bottom closest to the front of the car by the radiator. due to this my car is leaking from that spot does anybody have any suggestions because i heard this is a common problem.
Old Jan 3, 2008 | 10:36 AM
jmm96gsr's Avatar
Default Re: problem with down pipe please help (pbzhb)
Please list- engine, turbo, manifold/ downpipe combo. And a pic would be helpful.
Old Jan 3, 2008 | 04:26 PM
97grnrs's Avatar
i think i know which one u mean. does it sit under the bend on the pipe? sometimes u gotta dent the pipe a tad bit to get it in. and sometimes that has to be the first bolt u start before the rest are put in so u can tighten it right
Old Jan 3, 2008 | 05:08 PM
jmm96gsr's Avatar
Default Re: problem with down pipe please help (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">i think i know which one u mean. does it sit under the bend on the pipe? sometimes u gotta dent the pipe a tad bit to get it in. and sometimes that has to be the first bolt u start before the rest are put in so u can tighten it right </TD></TR></TABLE>
well, I'm sure that's the situation the OP is in, more than likely he has a 3" DP that wasn't dented in at the flange or they didn't use a a 2.5" to 3" transition. Maybe try grinding away the weld at that spot and indenting that area and rewelding??
Old Jan 3, 2008 | 05:50 PM
96 GSR-T's Avatar
I have an extremely tight fit on mine, using a 2.5" flange with 3" pipe welded right to it. I just barely dented it in and I used stainless allen head bolts to eliminate having to put a socket on it.
Old Jan 3, 2008 | 05:59 PM
RCautoworks's Avatar
Default Re: (96 GSR-T)
Depends on how tight the bend is but can you get any short bolt in there ? Maybe use a stud and thread on the nut before you seat the downpipes all the way
Old Jan 3, 2008 | 06:07 PM
NeKe1point0's Avatar
a pivot joint for a socket wouldnt do it ? otherwise as stated above, try the allen wrench.
Old Jan 3, 2008 | 06:22 PM
95dc2teg's Avatar
Default Re: (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">Maybe use a stud and thread on the nut before you seat the downpipes all the way
thats how i did mine and it worked out pretty well
092eg6
Welding / Fabrication
10
Jan 14, 2011 08:21 AM
wrinkles
Sep 15, 2006 04:35 AM
LostCRX
Jun 5, 2005 10:40 PM
R-1303
May 26, 2003 05:58 PM
