TIAL 38mm wastegate help
is it a must to have a tial flange. cuz I got a flat flange on my mani and when I bolted the wastegate with the metal gasket and seating ring, the wastegate doesnt sit flush only the ring is flush. is that the way it is suppose to sit? help appreciated
Re: TIAL 38mm wastegate help (Mr.Blondie)
snap a quick picture of it and post it if you want to best show us what you mean.
that valve seat ring is a VERY tight fit, be sure that it was not binding in the lower body because it was slightly cocked or something like that...which would not allow the wastegate to snug down to the flange.
maybe I am just misunderstanding your description but it sounds like there is a gap between the flange and the lower body of the gate. which there should not be when tightened down on the flange, the valve seat ring should push up into the lower body... and final result should leave the flange and lower body of the gate fitting flushed together.
Modified by twkdCD595 at 2:27 PM 1/8/2008
Re: (Mr.Blondie)
That's because...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 »</TD></TR><TR><TD CLASS="quote">there is a gap between the flange and the lower body of the gate. which there should not be when tightened down on the flange, the valve seat ring should push up into the lower body... and final result should leave the flange and lower body of the gate fitting flushed together.
Modified by twkdCD595 at 2:27 PM 1/8/2008</TD></TR></TABLE>
Re: (.adam.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .adam. »</TD></TR><TR><TD CLASS="quote">looks good to me......as long as that ring is sealed then you should be fine, and that gap is minimal</TD></TR></TABLE>
Re: (.adam.)
yep, it sounded much worse in your description than whats pictured. if it is leaking, you will know pretty quickly... you will see carbon tracks on the flange.
