question about gear controlled boost.
Old Jan 7, 2008 | 10:07 PM
Fo-Do Fanatic's Avatar
Default question about gear controlled boost.
i didn't know exactly what to call it but its pretty much what it means. i was reading somewhere that, i can't remember if its hondata or not, you can controll boost by what gear your in
for instance, from a dead stop you can be at 4psi in first, 9psi in second and full boost from third on out.
any insight on this guys?
thanks!
Old Jan 7, 2008 | 10:11 PM
.adam.'s Avatar
theres multiple different boost controllers and management systems that offer this, i use the apexi avcr........
Old Jan 7, 2008 | 10:12 PM
vietjdmboi's Avatar
hondata s300 has the boost by gear you are talking about.
Old Jan 7, 2008 | 10:15 PM
Default Re: (vietjdmboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietjdmboi &raquo;</TD></TR><TR><TD CLASS="quote">hondata s300 has the boost by gear you are talking about.</TD></TR></TABLE>
thats what i thought. My buddy and I are piecing his LS-V turbo setup right now. I want him to run s300 over any other ecu, best bang for the buck. but once he goes ls-v he'll need a new clutch and possibly possibly new injectors,
right now he has a stock ls teg running 10psi and making 223whp and i believe a little under 200wtq, and he has an exedy stage 2 clutch. dont know how long that'll last. i know clutches aren't rated by horsepower they are rated by torque, we'll just have to see.
Old Jan 7, 2008 | 10:42 PM
.adam.'s Avatar
i would also look into neptune rtp.......i dont know if it offers the boost by gear, but its cheaper than hondata, offers alot, and has a great rep
Old Jan 7, 2008 | 11:55 PM
hellakapps's Avatar
Default Re: (.adam.)
avc-r but it's not fun to set up
https://honda-tech.com/zerothread?id=1033497
Old Jan 8, 2008 | 12:09 AM
.adam.'s Avatar
whats the revelance of the link you posted?
Old Jan 8, 2008 | 01:05 AM
Outkast95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .adam. &raquo;</TD></TR><TR><TD CLASS="quote">whats the revelance of the link you posted?</TD></TR></TABLE>
exactly what I was thinking.
Old Jan 8, 2008 | 05:03 AM
Blown90hatcH's Avatar
Default Re: (hellakapps)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hellakapps &raquo;</TD></TR><TR><TD CLASS="quote">avc-r but it's not fun to set up
https://honda-tech.com/zerothread?id=1033497</TD></TR></TABLE>
wrong one....
https://honda-tech.com/zerothread?id=1037051
Old Jan 8, 2008 | 06:11 AM
Turbo-charged's Avatar
Default Re: (Blown90hatcH)
this will do all that along with have an adustable ramp rate. it can run spring pressure, stage 1 is your ramp rate, and then a 2nd stage that goes straight to target pressure. works great.
Old Jan 8, 2008 | 06:36 AM
KevonN's Avatar
I has a crayon!
Default Re: (Turbo-charged)
does AEM EMS have this feature?
Old Jan 8, 2008 | 08:47 AM
PHDZINE's Avatar
Default Re: (Fo-Do Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fo-Do Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">
right now he has a stock ls teg running 10psi and making 223whp and i believe a little under 200wtq, and he has an exedy stage 2 clutch. dont know how long that'll last. i know clutches aren't rated by horsepower they are rated by torque, we'll just have to see.</TD></TR></TABLE>
You dont need a gear based boost controller for that much power. Two stage will work fine.
Old Jan 8, 2008 | 08:51 AM
vietjdmboi's Avatar
actually, just get some bfg DR's and youre good to go.
Old Jan 10, 2008 | 08:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietjdmboi &raquo;</TD></TR><TR><TD CLASS="quote">actually, just get some bfg DR's and youre good to go.</TD></TR></TABLE>
tried them. he still spins through second because he doesn't have an LSD
streetsports1
Engine Management and Tuning
Jan 11, 2014 05:29 AM
rfelix89
Sep 7, 2012 06:59 AM
team_ibR
Dec 31, 2010 04:42 PM
purpleh22
Oct 18, 2009 01:34 PM
Bonestock98GS
Mar 8, 2008 07:29 AM
