max-rev vs. inline pro.
Old Feb 19, 2003 | 11:17 AM
rcsivtec07's Avatar
Default max-rev vs. inline pro.
i am building my own custom turbo kit. and i have been doing alot of research on what parts i want to use. i am stuck between the max-rev and inline pro mani's. i have heard good things about both of them and was just wondering if the fellow ht memebers could give me there opinions to which one they would prefer.
thanks
Old Feb 27, 2003 | 05:47 AM
integra-modder's Avatar
Default Re: max-rev vs. inline pro. (rcsivtec07)
whats your opinions guys....inline pro or max rev? max rev is on sale now for 400 new...
Old Feb 27, 2003 | 06:45 AM
badCRX's Avatar
New User
Default Re: max-rev vs. inline pro. (integra-modder)
If you go with Max-Rev, which my roommate did, you will want to make sure you have a 4 bolt exhaust housing. With the Inline pro, you will want a 5 bolt exhaust housing. The Max-Rev supposedly needs no cutting of the block to fit your standard T3/T04E turbo, and supposedly a T3/60-1 will fit as well. Our block was already cut from a previous turbo kit, but it looked like it would have cleared. I am not sure about the Inline pro needing any cutting of the webbing. I think the Max-Rev would be equal in performance with the Inline Pro, and would save my money with the Max-Rev one. Plus I have seen some that were polished very nicely and looked dope at the same time.
Old Feb 27, 2003 | 07:03 AM
LshatchTurbo's Avatar
New User
Default Re: max-rev vs. inline pro. (badCRX)
I think it just comes down to cost. How much can you afford etc. Both are log type manifolds, and essentially, a log is a log. Inline Pro also has a stainless steel version of the manifold which could be polished as well for some serious bling. But basicaly it just comes down to what you can afford IMO. The maxrev is cheaper so I went with it. It also allows as you mentioned to fit a Garrett 4bolt in there, which are usually cheaper as well. I fit one in a my hatch and barely did any modifications at all, although its a tight fit. Slim fan is recomended if you have EG
Its kinda like that big debate that people who do swaps always have: b18b vs b16a2.
Like people alway ask which one to swap into there civics etc, but really i have never seen a b18b swap go more for a b16a2, the ls is always cheaper....anyways I was just trying to put some stuff into perspective
[Modified by lshatchturbo, 11:12 AM 2/27/2003]
Old Feb 27, 2003 | 07:23 AM
Overblown-Teg's Avatar
Default Re: max-rev vs. inline pro. (lshatchturbo)
Didn't the maxrev used to cost $349? how is $400 the on sale price now? I guess since business is doing well prices get to go up. yeah.
Old Feb 27, 2003 | 07:29 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: max-rev vs. inline pro. (Overblown-Teg)
https://honda-tech.com/zerothread?id=402894
Old Feb 27, 2003 | 07:34 AM
C-Murdock's Avatar
Default Re: max-rev vs. inline pro. (Arturbo)
is there even a question that the inline pro manifold is so much better than the max-rev ? I dont think so...
Old Feb 27, 2003 | 02:34 PM
rcsivtec07's Avatar
well thanks guys for your suggestions and also to arturbo for that theard really helped me make my decesion to which manifold to use with my setup.
Old Feb 27, 2003 | 02:47 PM
vtec.dc2's Avatar
i chose inline pro cause it has wastegate outlet more in the middle - which i hope will allow better boost control and quality of the manifold - i don't think it will crack as easily as others - and use 5 bolt turbo if possible..
Old Feb 27, 2003 | 02:58 PM
Precision DC4's Avatar
Ok so the Max-rev and the Inline Pro are for two different types of turbos basically.
What about a comparison between the Inline Pro and the RevHard manifold? They are both for 5 bolt turbo's correct? Any outstanding differences, or does it just come down to price with these as well?
Old Feb 27, 2003 | 03:07 PM
vtec.dc2's Avatar
Default Re: max-rev vs. inline pro. (BlackIntegraLS)
well.. you can use 4 bolt turbo with inline pro - but you might have to shave some of the block...
and inline pro and revhard fit the same way - in my case i run revhard kit with inline pro manifold so i don't have to spend money on custom downpipe.
Old Feb 27, 2003 | 03:36 PM
Default Re: max-rev vs. inline pro. (vtec.dc2)
Custom downpipe? I don't get how having an inline pro manifold would change anything involving the downpipe. Please explain.
Old Feb 27, 2003 | 08:38 PM
vtec.dc2's Avatar
inline pro manifold was the first thing i got, i learned that revhard manifold and inline pro line up the same way - so i purchased revhard kit next.
Old Mar 7, 2003 | 09:23 PM
If you change the exhuast manifold, it will usually change the position of the turbo as a whole, thus requiring a custom down pipe.
These units are swapable...
Old Mar 7, 2003 | 10:32 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
The Max-Rev supposedly needs no cutting of the block to fit your standard T3/T04E turbo, .
I have the maxrev manifold, and I had to shave my block to get my turbo to fit. Not a big deal though. Just the fin, and the tab under the engine code had to be shaved off. Here's a pic of the problem with fitting the turbo with my maxrev manifold.
Old Mar 7, 2003 | 11:05 PM
New User
Default Re: max-rev vs. inline pro. (Snafu-Si)
Is that a Garrett or Turbonetics Turbo? Also what trim is that. My garrett T3/T04e fit without any shaving of the block.
Old Mar 8, 2003 | 12:25 AM
Snafu-Si's Avatar
It's a Garret, I believe it's the t3/t4e, but I'm not sure, where can I see to make sure what it is.. then again, that would be hard considering it's already installed.
.60 comp
.48 a/r
Old Mar 9, 2003 | 02:38 PM
I just bought an Inline Pro manifold, do you guys think I will need a 90 degree elbow for the TIAL WG?
Old Mar 9, 2003 | 03:06 PM
racecarpete's Avatar
are all these manifolds a/c compatible? ie. inline pro, maxrev,rev-hard
Old Mar 9, 2003 | 03:33 PM
jinxproof99's Avatar
New User
Default Re: max-rev vs. inline pro. (SilverCivic2k)
you can run a/c with the inline t3 manifold.
Old Mar 9, 2003 | 03:34 PM
New User
for an integra you will.
Old Mar 9, 2003 | 06:01 PM
93LSivic's Avatar
Default Re: max-rev vs. inline pro. (jinxproof99)
Im selling my polished maxrev manifold along with a/c compatible 2.5" dp, and turbo too....if anyone is interested.
New goodies coming soon!
Old Mar 9, 2003 | 06:18 PM
dfoxengr's Avatar
Default Re: max-rev vs. inline pro. (93LSivic)
Inline is way sexier, and better not to forget... it's cast unlike any other im aware of...no welds here...
Old Mar 9, 2003 | 06:44 PM
Default Re: max-rev vs. inline pro. (hybridvteceg)
I agree!
Old Mar 9, 2003 | 06:55 PM
dfoxengr's Avatar
gotta love our locals huh
