Boost Controllers and Turbo Timers
Old Feb 20, 2003 | 06:18 PM
smallttocs's Avatar
Default Boost Controllers and Turbo Timers
what are Boost Controllers and Turbo Timers? from what ive read they are just an add on item to fi correct? not necessary? did a search but no general info came up. thanks guys
Old Feb 20, 2003 | 07:03 PM
poid's Avatar
Default Re: Boost Controllers and Turbo Timers (smallttocs)
Boost controllers are used to run a higher level of boost than the wastegate spring allows. A turbo timer is simply a relay that keeps the engine running after you turn the car off for a set amount of time to cool the turbo down.
Neither item is necessary, but you'll need a boost controller to up the boost. Instead of a turbo timer you can simply take it easy before parking or sit in the car for a minute when you stop
Old Feb 22, 2003 | 08:19 AM
smallttocs's Avatar
Default Re: Boost Controllers and Turbo Timers (poid)
thanks
Old Feb 22, 2003 | 09:47 AM
boostedsol's Avatar
I think it's good to have a timer tho. For instance, whenever I have a test for college, I'm always late and don't have the extra couple of minutes needed to cool down the turbo. You can just wait a bit in the car before you shut it down to cool off/lube the turbo, but I just find that as an inconvenience personally.
dcrboost
May 4, 2011 07:51 PM
brasilstreet
Jun 16, 2004 02:21 PM
phase12gsr
Apr 10, 2002 03:30 PM
