For those with OBDII to OBDI conversions
I just put in an OBDII to OBDI conversion harness with a P28 ECU into my D16Y8. The problem is, I get a CEL number 9, cylinder position sensor. Is this normal? If it is, how do I get rid of it? Or do I have a defective ECU or harness?
Re: For those with OBDII to OBDI conversions (swrdply400mrelay)
Ok edit: The CEL was actually a number 19, my fault. Code 19: Lock-up Control Solenoid Open or short in LCS circuit, defective LCS solenoid. We took apart the ECU and it looks virgin. I put it into my friend's car and he got the CEL too. Anyone know how I can fix it?
Re: For those with OBDII to OBDI conversions (Tinker219)
Lock up control selenoid?
Im not sure what that is even...sounds like something for a tranny...
37820-p28-A52
I was told it's an automatic ECU. A "1" instead of "5" would be a manual.
What is the part number on your ECU? 37820-P28-XXX. I need to know the XXX part. Sounds like you have an auto ECU. Its pretty easy to change to manual though.
New User
Re: For those with OBDII to OBDI conversions (Jaker)
wait, so if u have an auto ecu, and u wanted a manual ecu, it would be easy to change?? please explain thanks
Re: For those with OBDII to OBDI conversions (PolosportZ81)
would it not be easier if u just got a manual one??
Check with B18C-EJ1 on this board. He sells P28's and does programming of them. He was quick to reply to questions from me.
Pistolero281
05-26-2017 12:44 PM
