dsm injector question
Old Feb 19, 2003 | 08:35 PM
DD_JonnyLee's Avatar
Default dsm injector question
i am currently running dsm 450's , a 12:1 fmu and a safc to control the injectors, i have fuel at -30 acroos the board, i am running 9 lbs and 13 degrees timing, my question is . how much fuel can i safely pull out??? i would also like to turn the boost up a few lbs.....
tia
jonathan
Old Feb 19, 2003 | 09:24 PM
1bar's Avatar
Default Re: dsm injector question (TrboGSR)
From what i have read it seems that you can take your fmu out. And the Safc is only go to around 10-12 lbs before you get a cel. There is a good thread that was written by liam28 i believe. You may have to lean out the 450 a little more though, -35 .
Old Feb 20, 2003 | 10:47 AM
Default Re: dsm injector question (1bar)
i tried the hack and it made my car run like the poo, so i stuck the fmu back on and it runs good, i was just wanting to pull some more fuel out cause its runin really fat up top
-jonathan
Old Feb 20, 2003 | 10:50 AM
turbod16y8's Avatar
take the fmu out and tune it some more. theres no need for a fmu with the vafc and 450cc. tune it and itll run 10 times better then the fmu setup.
Old Feb 20, 2003 | 10:57 AM
swlabhot's Avatar
As stated, get rid of fmu. 450s and afc + tuning will do the trick. U'll likely want to trim it a little more like closer to -40 across. 10-11psi would be the max u can run with stock O2.
A search will find you countless threads on this
Old Feb 20, 2003 | 11:31 AM
Default Re: dsm injector question (swlabhot)
i did a search , and i dont like the hack, what does the o2 sensor have to do with it??? you mean map???
-jonathan
hybridb18
Apr 24, 2003 08:45 AM
hybridb18
Apr 21, 2003 10:46 AM
untitled
Mar 19, 2003 06:27 AM
Sohc Driver
Mar 15, 2003 11:42 AM
Fatty_1775
Nov 15, 2002 03:07 PM
