Dyno in Two Weeks, whp estimation ?
Old Feb 20, 2003 | 12:07 PM
C-Murdock's Avatar
Default Dyno in Two Weeks, whp estimation ?
Well the block is being put back together with a flat deck surface so hopefully it wont leak. Im sure this raised compression a bit so we are running a thicker headgasket to prevent compression being too high. I would like to see what kind of whp you all think i will make. Im going to run about 15psi on pump gas, and 20+ (However much I can run) on C16. Setup is as follows :
H22A4
Golden Eagle Sleeves
Crower Rods
Arias 10:1 Pistons
Inline Pro Headgasket
Port and Polished Head
Crower Turbo Cams
Crower Valvesprings
Crower Retainers
T3/T04E 60 Trim Stage 3 wheel, .82a/r exhaust, .60a/r compressor
Spearco 24x6.5x3.5 Intercooler
Revhard Log Style Manifold
Tial 40mm Wastegate
HKS SSQ BOV
2.5 Downpipe Flared to 3"
3" Testpipe and Custom 3" Mandrel Bent Exhaust to 3" Apexi N1 Turbo Muffler
MSD 72lb/hr injectors
AEM Fuel Rail
Aeromotive Fuel Pressure Regulator
Tuning with the AEM EMS...
[Modified by C-Redrum, 4:08 PM 2/20/2003]
Old Feb 20, 2003 | 12:16 PM
jinxproof99's Avatar
New User
Default Re: Dyno in Two Weeks, whp estimation ? (C-Redrum)
pump gas estimations??? your guess is as good as mine, however i would not run 20 lbs. and if it was me, i'd stick close to 350 to the wheels for safety purposes.
race gas??? my guess is somewhere around 475 - 500 to the wheels on race gas due to the turbo and injector size. just my opinion. good luck and let us know.
Old Feb 20, 2003 | 12:18 PM
C-Murdock's Avatar
Default Re: Dyno in Two Weeks, whp estimation ? (jinxproof99)
no way 20lbs on pump gas, im sorry if i made you think that....350 to the wheels on pump gas ? hmm that would be nice...
Old Feb 20, 2003 | 12:22 PM
New User
on your fully built motor, 350 will be achieved easier than you think. any guesses??? under 12 lbs of boost. ****, under 10 on a straight t4. i think you'd be fine with 93 octane and 350 to the wheels. some on here will say over 400, but i'd stick to the side of safety. your gonna have so much torque with 350 to the wheels on your 2.2 motor, it'll practically be unusable anyway. lol.
[Modified by jinxproof99, 4:23 PM 2/20/2003]
Old Feb 20, 2003 | 12:25 PM
C-Murdock's Avatar
haha..Well remember, im on a t3 turbine. Im just trying to get a 5th gen Prelude into the 11's. I have never seen one anywhere. I know they are fat asses, but I removed A/C, gutted interior, carbon fiber hood, etc. On C16, im sure its more than possible.
stick's Avatar
looks good. very nice set up. got any pics?
whats stock compression on the H22?
how come ur not using stock camshafts?
no cam gears?
stock redline?ECU?
300+ is what im guessing.
Old Feb 20, 2003 | 12:28 PM
New User
invest in some axles and be looking for low 11's with at least 450 to the wheels. your weight is the only thing keeping you out of the 10's.
Old Feb 20, 2003 | 12:30 PM
C-Murdock's Avatar
Default Re: Dyno in Two Weeks, whp estimation ? (stick)
No Pics yet...very soon.
10:1
As the cams are titled, they are made for Turbo applications, im sure they can't hurt. Do you think they will make less horsepower than stock camshafts ? I wouldn't bet on that.
no cam gears?
With the profile of my camshafts, Im not sure if i will need cam gears. They probably couldn't hurt.
stock redline?ECU?
Read...I am using the AEM EMS...as for the redline ? Im sure my tuners will raise it accordingly.
[Modified by C-Redrum, 4:30 PM 2/20/2003]
Old Feb 20, 2003 | 12:32 PM
C-Murdock's Avatar
Yes, I am going to get some Driveshaft shop axles and wait till I break my stock ones. I might as well break them, otherwise im not getting anything out of them at all.
Whenever I become very speed hungry, im going to find a Civic HB or CRX rolling chassis and drop my setup in there, then maybe a Type S motor back in the Lude and go all motor for an everyday driver to replace my piece of **** truck.
btw Jinx, what type of sleeves were in your HB ? Was your car tuned at Inline Pro ? Im about an hour and 30 min away from them...Hagerstown, MD.
[Modified by C-Redrum, 4:33 PM 2/20/2003]
Old Feb 20, 2003 | 12:53 PM
New User
i'd get the axles now from DDS and sell your prelude ones. i think you will break them the first day at the track. you will get very few passes with them. at least have a truck and trailer with you for towing cause you will need it. hahaha. inline tuned my car and i made 510 to the wheels on stock, b series sleeves. inline purchased the car from me and later made over 550 on the same motor. they did the tuning.
Old Feb 20, 2003 | 01:34 PM
turbologist's Avatar
did they do anything else to get that 40whp?? Conspiracy? Cant be...Not to take the light away from u c-Redrum but what kinda whp would a 95gsr need to be in the 10's? Being that all the body panels are stock?
[Modified by Turbologist, 10:35 PM 2/20/2003]
Old Feb 20, 2003 | 02:49 PM
New User
Default Re: Dyno in Two Weeks, whp estimation ? (Turbologist)
what???? they turned the boost up.. thats it as far as i know.
Old Feb 20, 2003 | 07:30 PM
I wasnt implying anything...Inline are good people...I can attest to that..
Old Feb 20, 2003 | 07:53 PM
SiRkid's Avatar
sounds awesome.cant wait to see.
C-Murdock
Oct 15, 2003 08:06 AM
C-Murdock
Oct 5, 2003 07:16 PM
C-Murdock
Aug 17, 2003 02:06 AM
C-Murdock
Nov 7, 2002 07:55 PM
