Misfire codes 72, 73, 74 after AEM FPR install
Last night I installed my AEM FPR. I have a 99 Civic Si w/Greddy turbo and Walbro 255 lph high pressure fuel pump. I changed the orifice to the silver one (mid size) from the stock black, and set the fuel pressure with the vacuum line disconnected and plugged to about 45 psi. Today the check engine light comes, which turned out to be codes 72, 73, 74 for random misfire. I reset the ECU and adjusted the pressure a little higher to about 47 psi. I reset the ECU again after adjusting the pressure. Should this fix my problem or do I need to go with the largest orifice since I have the high pressure Walbro?
Re: Misfire codes 72, 73, 74 after AEM FPR install (Evil Beaver)
I'm using the smalles orifice and a walbro with no problems.
I'm only running 36 psi though. Try turning it down not up.
Re: Misfire codes 72, 73, 74 after AEM FPR install (niedejb)
switch the orfice to the bigger size one and that will fix the prob garunteed, i had the same prob .
its becuase the pressure from the walbro pump .
[Modified by itr206, 5:26 PM 2/19/2003]
Re: Misfire codes 72, 73, 74 after AEM FPR install (itr206)
If you took it apart I will put money on it that when you put it back together you pinched the diaphram and now its cracked...It happened to me and it caused the same problem.
Re: Misfire codes 72, 73, 74 after AEM FPR install (BVM)
BTW, I called AEM tech support and they didn't even know what a misfire was.
diet rite
12-14-2005 07:13 PM
Firedrake
07-18-2003 01:48 PM
