Fuel return line size?
Old Feb 18, 2003 | 11:00 PM
Blown90hatcH's Avatar
Default Fuel return line size?
I am working on my fuel system and I have a question about the return line. Goal is approximately around 450-500 whp. Is the stock return line on my 2000 civic hb sufficient enough to be the only return line? I am going to setup the aeromotive 1000hp pump, regulator, 75lb injectors, etc.
Thanks, JAson
Old Feb 19, 2003 | 01:06 AM
rcsivtec07's Avatar
Default Re: Fuel return line size? (Blown90hatcH)
i would personally use -10 fuel feed and -8 for your return line for your setup. this setup should be able to produce from 800 to 1000 hp. anyone correct me if i am wrong.
Old Feb 19, 2003 | 04:03 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Fuel return line size? (rcsivtec07)
I used a -8 and -6 line respectively, and i run a similiar setup to yours, or the one you are trying to assemble.. I didnt use the stock lines, but rather an -8 feed from the pump and a -6 return from the rail. that should be sufficient enough for your designated HP goal.. good luck
Old Feb 19, 2003 | 07:21 AM
BROOD's Avatar
Default Re: Fuel return line size? (SIXTYdashONE)
I'm also running a 8AN feed/6AN return system. Using the aeromotive pump, fpr, filter, GEM rail, and RC 550's. It works well. I think 10AN feed/8AN return is alittle too much for your needs.
You could probably use the oem return line and a SS feed line. In my case the extra cost to run full SS lines for both feed and return (compared to SS braid on only the feed) was not unmanagable. I ran full SS braid for both lines. Good luck
[Modified by SLPR, 8:24 AM 2/19/2003]
Old Feb 19, 2003 | 08:00 AM
jinxproof99's Avatar
New User
Thanks, JAson
stock is fine. when you decide to run over 500-525, go with the 10 feed and 8 return.
Old Feb 19, 2003 | 08:31 AM
SuperT's Avatar
I run the aeromotive pump myself and utilize -8 feed and -6 return and it is on a 700hp 2jzgte supra motor...
Old Feb 19, 2003 | 08:52 AM
ekb18c's Avatar
I run a -6 return and -8 feed line also.
Old Mar 3, 2003 | 08:52 AM
integra6650's Avatar
Default Re: Fuel return line size? (ekb18c)
what size is the stock supply hard line
Old Mar 3, 2003 | 08:58 AM
Flamenco-T's Avatar
Default Re: Fuel return line size? (integra6650)
1/4"
Old Mar 3, 2003 | 08:59 AM
Smashback's Avatar
-10 and -8 would probably support over 1000 HP and is way bigger than you need. -6 and -4 should support over 600 HP easy. You can always use a larger return...it can't hurt but it can help prevent pressure from building in the return.
Old Mar 3, 2003 | 09:46 AM
autoEXturbo's Avatar
yep, stock will do. I'll be using -10an and stock return once it goes it for the new pump.
Old Mar 3, 2003 | 09:47 AM
b18bturbo's Avatar
Default Re: Fuel return line size? (autoEXturbo)
i run -8 -6 setps usually they cheaper too
jdm_h22
Jan 7, 2016 05:58 AM
dmotoguy
Mar 2, 2008 10:27 AM
1QwIkEf
Jan 28, 2006 05:05 PM
