Garrett GT30 Downpipe Size??
Old Feb 18, 2003 | 07:28 AM
cjb80's Avatar
Default Garrett GT30 Downpipe Size??
The Garrett GT30 uses a T3 exhaust housing, and the flange opening is a little smaller than 2.5". I wanted to run a 3" exhaust, is there any advantage to using a 3" exhaust if the exhaust housing outlet is only 2.5"? Would there potentially be an advantage to using a 2.5" downpipe?? (velocity?)
Also, if I were to go with 3", I would have to mate a 2.5" pipe to the flange, and somehow grow it to 3". How would you go about doing this transition?
Thanks!
Chris
Old Feb 18, 2003 | 08:01 AM
SiRkid's Avatar
Default Re: Garrett GT30 Downpipe Size?? (cjb80)
most turbos do not have a 3" outlet..
so running 3" will be fine..
the dp flange is a standard 4 bolt..so you can easily make a straigh 3" exhaust
Old Feb 18, 2003 | 08:44 AM
PeakBoost's Avatar
B*A*N*N*E*D
hey chris, you should post those pics of your turbo..
very nice, garrett GT30/35
Scott53092
Feb 12, 2014 12:54 PM
alperx
Aug 22, 2011 06:52 AM
LilCivic04
Oct 27, 2005 08:50 AM
AspectIndustries
Apr 10, 2004 12:23 PM
egg
Jun 10, 2003 01:25 AM
