afc hack-----greddy blue box
Old Feb 18, 2003 | 08:12 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default afc hack-----greddy blue box
i have been reading alot into turbo setups and im still slow on ther fuel setup parts, my kit is almost pieced together and i just need some management now, i was planning afc hack, but i was wondering what is the cheapest you can do for stock dsm turbo on dohc zc motor, is it possible to just hook up a greddy blue box?
Old Feb 18, 2003 | 09:19 AM
Daniel's Avatar
Default Re: afc hack-----greddy blue box (Y49CRXSIZC)
yeah, you can use just the GReddy blue box, but i don't know how you would wire it to the ZC's computer. i only have diagrams for 92-00 D16z6, d16y8, and b16. if you want to try, though, i'll be selling my blue box in about a month. let me know if you want it. It's good from 5 psi - 7 psi. some say 8, but that might be pushing it a little. Also intended for use on stock injectors (mine was flashed for SOHC Civics).
EDITED for grammar/spelling.
[Modified by Daniel, 6:20 PM 2/18/2003]
Old Feb 18, 2003 | 10:56 AM
Guess whos bizzack
Default Re: afc hack-----greddy blue box (Daniel)
well someone has to have a diagram, cause i know alot of people use the 92 up civic kit on ZC crx applications.
Old Feb 18, 2003 | 11:04 AM
Daniel's Avatar
well, you can probably just put 2 and 2 together ... read what wire is what on the blue box and hook that up to the appropriate wire on the ZC computer. Go to http://www.turbocivic.net for FCU wiring pictures.
Old Feb 18, 2003 | 11:20 AM
liam821's Avatar
25 Year Member
from my reading the greddy bluebox is only good for about 7psi while the afc hack is more around 10-12psi depending on your afc settings.
The afc hack also gives you move control over the fuel as it is a fuel controller after all.
But if your goal is 5-6psi of boost...and dont want to goto the trouble of getting DSM injectors and buying an afc..greddy blue box might be for you.
liam
Old Feb 18, 2003 | 12:01 PM
Guess whos bizzack
Default Re: afc hack-----greddy blue box (liam821)
ya thats why i am thinking about it, cause its cheaper, the only problem is isnt the t25 from an eclipse set at 8 psi? so how would i use the box then?
Old Feb 18, 2003 | 01:31 PM
liam821's Avatar
25 Year Member
The internal wastegate on the t25 from the 2g eclipse is ~10psi. You would need to modify the internal wastegate on the t25 to lower the boost.
TEC (Turbocharger engineering corp) in golden colorado will sell you a kit to do just this (lows the boost to 6psi) and sells for about $75.
Turbo Charger Engineering Corp (303) 271-3997
17222 S. Golden Rd # G
Golden, CO
thanks,
liam
Old Feb 18, 2003 | 08:47 PM
Guess whos bizzack
ok liam thanks for the company, so i can use the stock injectors/fuel system with this setup then? And has anybody come up with a wire diagram?
thanks for all the help, i found a blue box for sale cheap too
Old Feb 19, 2003 | 06:57 AM
Guess whos bizzack
ttt
Bimmerman
May 6, 2005 04:30 PM
lDanny
Mar 30, 2005 02:14 PM
93TurboSi
Sep 30, 2003 08:46 PM
boostincoupe
May 20, 2003 03:29 PM
99ls
May 12, 2003 01:10 PM
