I need help picking the appropriate turbo...
Old Feb 18, 2003 | 04:26 PM
HondaHanger's Avatar
Default I need help picking the appropriate turbo...
I am in hopes of getting a 94-96 integra Ls, I am also in hopes of dropping some sort of turbo in it. I do not know much about turbos, so I come to the good people of honda tech for answers . What would be the most efficient turbo, I guess I want it to spool at roughly 4000 rpms and be capable of delivering around 200-250 whp. Once again, I don't know much. Any suggestions would be well appreciated, Thanks.
Steve
AIM screen name BlankEnsOmnIac
Old Feb 18, 2003 | 06:09 PM
B20-T's Avatar
Default Re: I need help picking the appropriate turbo... (HondaHanger)
go with a t3/t04e 60 trim turbo with .63ar.from cheapturbo.com
Old Feb 18, 2003 | 06:15 PM
glagola1's Avatar
How bout a turbo that spools at 2700 and puts down over 250 on 10psi? It sounds crazy especially on a board with such a fetish for the t3/t4 but the Apexi kit for the SOHC works awsome on an LS. It's like a little truck. I would never "upgrade" to a t3/t4 to run anything less than 14psi.
Old Feb 18, 2003 | 06:42 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: I need help picking the appropriate turbo... (glagola1)
Get a Precision Turbo and do it right the first time. That way when you want 350whp you dont need a new turbo. the sc50 will spool by 4k no problem and will support 350whp.
Old Feb 18, 2003 | 08:01 PM
DIRep972's Avatar
Smarter than you
garret T3/T04e 57 trim w/ stage 3 .63ar would probably be perfect for u. or a precision SC34.
made 250whp @ 10psi on my LS turbo. started spooling 3000 and had full boost(10psi) at 4000. doesn't seem laggy at all and pulls past redline.
Old Feb 18, 2003 | 08:05 PM
thenick's Avatar
Default Re: I need help picking the appropriate turbo... (DIRep)
im planning on going with a T3 a/r of .60-.63
it all depends where you want your power on the rpm range
AspectIndustries
Oct 15, 2007 04:03 PM
NuclearB18B
Jul 13, 2003 02:20 PM
Project_SOHC_EX
May 5, 2003 01:46 PM
Ivan
Jul 17, 2002 06:40 AM
