knife edged crank
Old Feb 18, 2003 | 09:42 AM
wrXtian's Avatar
Default knife edged crank
is it really worth it.. i'm thinking about buying a second crank and having it sent somewhere to have it knife edged.. some pple suggested it to me, but is it worth the time and money for it??
Old Feb 18, 2003 | 09:54 AM
BLAP BLAP!!!
Guest
Posts: n/a
Default Re: knife edged crank (xjdm94x)
any up grade to the motor is a good idea.. it just depends on how far you want to go with the motor..... if you are going with a totally built set up.. then yes it would be worth it.. but if you dont care about the motor too much then it would just be a waiste of money.....
Old Feb 18, 2003 | 10:29 AM
Therumblingteg's Avatar
Default Re: knife edged crank (turbocr-x)
No. Its a honda, the crank does not go through the oil, so you dont need to get it done, just micropolished and balanced.
Old Feb 18, 2003 | 05:12 PM
wrXtian's Avatar
Default Re: knife edged crank (Therumblingteg)
what does micropolishing consist of?
Old Mar 4, 2003 | 08:22 AM
joe_bocc's Avatar
knife edging a crack has nothing to do with it going through the oil, its to lighten the crank.
Old Mar 4, 2003 | 08:52 AM
Flamenco-T's Avatar
Default Re: knife edged crank (joe_bocc)
knife edging lightens the crank to have a lighter rotation mass when it spun inside the block...less drag. I have seen an almost spun main bearing got prevented because the crank was knife edged...
think about it this way, with less bulky crank, it is so much easier to turn, putting less load on the bearings to provide smoother rotation.
if your crank is out, I say go for it...
micropolishing is polishing the journal until it's shine and smooth that it makes it easier and lesser load on the bearing...
balancing is basically weight balance the crank to have an equal weight on both side. Honda crank usually doesn't need to be spin balance due the the direction of inline 4, transverse motor versus the V8 crank...
Usually they take all the parts that attaches to the crank like pulley, oil pump sprocket, flywheel and etc and balance it assembled..
again, if your crank is out, mind as well go for it...I can't think of any negative effects of having it done...
stan
Old Mar 4, 2003 | 09:03 AM
Charlie Moua's Avatar
Default Re: knife edged crank (Flamenco-T)
so it would be benificail only of you balance it WITH the flywheel, and pully of your choice right?
Old Mar 4, 2003 | 09:08 AM
Kevin's Avatar
Default Re: knife edged crank (Charlie Moua)
I wouldnt do it on a street car, just not worth the potential problems. Ive seen cranks go at the track and its not a pretty site. Id want mine as strong as possible, just micropolished and balanced if that.
Old Mar 4, 2003 | 09:11 AM
Flamenco-T's Avatar
yeah.
about the knife edging, if it's done properly, I don't think it would compromise the stregth of the crank itself, but again it comes down to the choice of a heavier stronger crank, or (if not done properly) a lighter, less chance of seized bearing, but less stronger crank...
Old Mar 4, 2003 | 09:15 AM
blufke's Avatar
how much does it run "usually" to knife edge a crank?
Old Mar 4, 2003 | 09:17 AM
Flamenco-T's Avatar
Default Re: knife edged crank (blufke)
I have no idea, never had it done before. balancing and micropolish runs me 100
Old Mar 4, 2003 | 10:58 AM
BoostedH23a1's Avatar
KMS does it fof 465
Old Mar 4, 2003 | 02:44 PM
wrXtian's Avatar
Default Re: knife edged crank (BoostedH23a1)
i hear street driving w/ a knife edged crank w/ a lite flywheel is a bitch.. too light and ur idle is jacked.. but i duno from person experience.. just rumor.. can anyone vouch for that?
Old Mar 4, 2003 | 03:09 PM
Sonny's Avatar
KMS does it fof 465
It does look like a very time consuming process. I think I would spend that money on something else though.
Sonny
jdmjakebrehm
Jun 16, 2011 11:21 AM
Art701
Jun 24, 2003 06:22 AM
P73 DA9
Jun 15, 2001 01:42 PM
