vac. routing for deltagate
i have a drag 3 ls/vtec...on teh deltagate i teed teh vaccum line with the fpr and the bov is there also..is that ok??..also on the deltafate it seems like there is also another vaccum source at the top of it..should that be connected anywhere?? slight problem im running into is no boost..everything seems fine but just no boost and low revlimit(4400)
dont hook up your bov and fpr vacuum source there hook it off the manifold,and as for the top leave it open till u have a boost controller ..hook up the side to the compressor housing or intercooler pipe some may have it on t here instead having it on the housing
the side port will go to your turbo compressor housing
leave the top open
as for no boost, there could be a lot of reasons for that
check your wg and make sure it's not releasing exhaust gas early
leave the top open
