What pulley kit is better aem or unorthodox racing
i have a 01 honda civic ex what would be better for my car aem pulleys or unorthodox pulleys. or what should be my next mod.
Re: What pulley kit is better aem or unorthodox racing (black_honda01)
Pulleys are not necissary my friend...
EDIT: Stock pulleys are good...
[Modified by 631 Teggy, 10:19 PM 2/18/2003]
Re: What pulley kit is better aem or unorthodox racing (631 Teggy)
Go with the aem pulleys. They are accessory pulleys and won't harm the engine. The unorthodox pulleys remove the harmonic dampner on the crankpulley putting more stress on the oil pump and bearings.
Re: What pulley kit is better aem or unorthodox racing (Kamin)
If you can get any power at all for $150 out of a honda then it's worth it. The pulleys are one of the few things that actually have a good power:dollar ratio...
Re: What pulley kit is better aem or unorthodox racing (tony1)
i took out my PS and all i put on was the AEM alternator pulley, and yes i did feel a diff, and no its not in my head.
Re: What pulley kit is better aem or unorthodox racing (Suprdave)
I'm pretty sure we can order the alt. pulley only. Give me a call at the shop and i'll check on it for you...
I'm using AEM cam gear, AEM alt pulley, and Unorthdox racing crank pulley on my D16Z6 project right now and going w/ a Garrett T3 turbo. No ac or ps. I'm hoping this will be an ok setup since I'm hearing alot of bad stories about crank pulley.
Re: What pulley kit is better aem or unorthodox racing (cvcc)
Wow, pulleys really make a difference? I was always under the assumption that they made very little difference, and would only use them if you have extra money. I need to look into these then.
Re: What pulley kit is better aem or unorthodox racing (turboex)
what's the verdict..?
631 Teggy: Pulleys are not necissary my friend...
tony1: Go with the aem pulleys. They are accessory pulleys and won't harm the engine. The unorthodox pulleys remove the harmonic dampner on the crankpulley putting more stress on the oil pump and bearings.
Kamin: waste of money.
turbospool: i took out my PS and all i put on was the AEM alternator pulley, and yes i did feel a diff, and no its not in my head.
Civic_95_Si: I've had my UR set(Crank,Alt,&PS) for over a year and have had zero problems.
turboex: ran my complete unorthadox with crank pully for 60,000 miles. no probs yet
GreenMachineRex
13
04-26-2004 12:53 PM
