when is an upgraded fuel rail required?
Old Feb 20, 2003 | 09:21 AM
madman604's Avatar
Default when is an upgraded fuel rail required?
as topic says:
when would you require a larger capacity fuel rail (eg: STR or AEM) after 300+ HP or is it all a gimmic and the stock will do fine?
Old Feb 20, 2003 | 09:46 AM
m0t0rhead's Avatar
Default Re: when is an upgraded fuel rail required? (Turbo E)
as topic says:
I have seen peeps with stock ignitions and stock fuel setups with the exception of FPR and upgraded pump putting out over 500 HP.
Old Feb 20, 2003 | 10:07 AM
symba's Avatar
don't know what your setup will be, but as a reference, if you were using Hondata you would not need an aftermarket fuel rail or FPR. And the horsepower potentials utilizing Hondata are substantial. Well over 300
Unfortunately, I didn't do enough research and I had already purchased fuel rail. But I kinda like the Bling Bling affect.
[Modified by symba, 7:08 PM 2/20/2003]
Old Feb 20, 2003 | 10:10 AM
*Boostwerks*'s Avatar
I think there is a certain injector size, that after that point it is reccomended that you get a bigger bore fuel rail.
I however don't know that specificly, but I would say around 720cc.
Old Feb 20, 2003 | 10:23 AM
Smashback's Avatar
I didn't need one but I bought it because:
a. stock b series rails are UGLY...D series look great when polished
b. i suck at tapping so i decided it'd be easier to have the rail with an ports already drilled
Old Feb 20, 2003 | 10:25 AM
FBP Si 2000's Avatar
Default Re: when is an upgraded fuel rail required? (Hatchblack)
What about a fuel pump? When would it be best to upgrade that? I'm just aiming for 250whp. Hondata will be taking care of the fuel management.
Old Feb 20, 2003 | 10:36 AM
Smashback's Avatar
Default Re: when is an upgraded fuel rail required? (FBP Si 2000)
Yeah for any kind of power you need a better pump...any 255lph in tank will do...go with a standard pressure if you're not using an fmu. Good choice on the Hondata BTW....unlike some people here like to think, you don't have to use the AFC hack if you're running less than 300 hp.
Old Feb 20, 2003 | 10:40 AM
madman604's Avatar
looks like time to bust out the dremel and give the OEM rail a buffing
thanks guys.
[Modified by Turbo E, 11:42 AM 2/20/2003]
Quickridez_3
Dec 22, 2022 11:18 AM
bigG
Feb 14, 2017 10:14 AM
ghostriderinnc
Jul 31, 2010 09:38 AM
racekar711
Nov 22, 2005 12:13 PM
MilanoFury
Apr 1, 2004 09:05 AM
