crv pulley on jrsc
Old Feb 19, 2003 | 08:21 AM
GSR901's Avatar
Default crv pulley on jrsc
i have heard that the crv pulley is not made to spin as fast at it does with a JRSC b18c1. i know endyn makes a stepper pulley, is it 9 or 10 lbs. the crv will make about 10 lbs right? i can get a crv pulley for free but i dont want to use it if it is going to cause other parts to wear prematurely. i will be upgrading to hondata and larger injectors as well to help keep things safe. thanks.
Old Mar 19, 2003 | 10:46 PM
tegedrex's Avatar
Default Re: crv pulley on jrsc (B18Cwon)
been running one for the past few weeks no problem.
Old Mar 19, 2003 | 10:49 PM
Zero2Sixty's Avatar
Default Re: crv pulley on jrsc (tegedrex)
i ran one for about 6 months, did just fine for me.
Old Mar 20, 2003 | 09:57 AM
gitwidit's Avatar
I run jackson 8lb pulley on my blower and crv on the crank, have had no probs with exception of slight belt slip every now and then, totals 11lbs (sohc).
Old Mar 20, 2003 | 10:02 AM
BritSi's Avatar
Default Re: crv pulley on jrsc (GITWIDIT)
The Endyn stepper will give you 9 psi and will not overspin the alternator (because it is stepped). The CRV crank pulley will overspin the alternator but personally I wouldn't worry about it.
swaytec360
Jan 23, 2006 03:47 PM
boostedeghatch
Jun 19, 2005 04:18 AM
agratise
Jan 20, 2005 12:36 PM
Blk00EJ8
Jul 28, 2004 07:32 PM
Tiamat-blue
Dec 31, 2002 09:30 AM
