Autotuning question
Old Feb 18, 2003 | 11:03 AM
highbrid's Avatar
Default Autotuning question
Well i got autotuning to work on my car... sort of. I have the aem ems and it works at any load below 31 but when i get to 31 at any rpm itll start at 9, raise up and then go right back down to 9 when i accelerate some more. Have any of you had that problem?
Old Feb 18, 2003 | 11:04 AM
Civic_95_Si's Avatar
Default Re: Autotuning question (highbrid)
Que?
Old Feb 18, 2003 | 11:16 AM
highbrid's Avatar
Default Re: Autotuning question (Civic_95_Si)
if you dont have aem ems and you havent autotuned before then you probably dont understand. Im not really expecting someone to know, but this forum is probably the one to ask about this.
EMS forum=good idea
Old Feb 18, 2003 | 12:30 PM
Tinker219's Avatar
Im going to be tuning my ems soon...when you say 9....9 what? psi?
Old Feb 18, 2003 | 01:01 PM
highbrid's Avatar
Default Re: Autotuning question (Tinker219)
9.0:1 afr
Old Feb 18, 2003 | 01:04 PM
racerxadam's Avatar
have you filled out your target air/fuel ratio table completely? are you sure you are not going outside the range of your maps? what is your load axis set up in? psi?kpa?
Old Feb 18, 2003 | 01:23 PM
highbrid's Avatar
Default Re: Autotuning question (racerxadam)
i have the target filled out completely, my y axis is just the normal load vs. speed table that is default. I had it set up with psi but for some reason i like the normal setup better.
Another thing is when i hit vtec i get ungodly rich and it doesnt get any leaner
My Automap values dont seem to match with my target at all. Is there anything i can do in the initialise automapping menu?
Old Feb 18, 2003 | 01:30 PM
Mase's Avatar
what are your initialise automapping settings?
Old Feb 18, 2003 | 01:34 PM
highbrid's Avatar
Default Re: Autotuning question (Mase)
they are pretty much the way that they came from aem. Jp told me to keep them close to that. The only thing i changed was the weight before change, i changed it to 20. the error mult. is still -6, additive 0,
Old Feb 18, 2003 | 01:37 PM
Mase's Avatar
mine are
Weight before change: 15
Target Accuracy: .25
Multipler -7
and zero additive
Old Feb 18, 2003 | 01:38 PM
Mase's Avatar
also, what wideband are you using?
Old Feb 18, 2003 | 01:48 PM
highbrid's Avatar
techedge, can u share what ur o2 settings are also, im talking about the Vout vs. afr, i set it sort of equal to what techedge says, but my gain is below 1
[Modified by highbrid, 4:32 PM 2/18/2003]
Old Feb 18, 2003 | 01:50 PM
highbrid's Avatar
also did you change your automapping table to match ur target table and do you have o2 feedback control on or off?
[Modified by highbrid, 4:33 PM 2/18/2003]
Old Feb 18, 2003 | 04:54 PM
Mase's Avatar
my gain is 1.7,
and the graph looks like the y = x^2
if you followed it from techedge, im sure its fine
TURN O2 FEEDBACK OFF WHILE AUTOTUNING!!!!
Old Feb 18, 2003 | 07:05 PM
KOTSEMOTO's Avatar
I don't have EMS but I have autotuning. My hunch is that you are out of range of a certain AFR. Autotuning works for a certain AFR line 9.0:1 upto 17.0:1
BE sure to check whre you set yours.
Old Feb 18, 2003 | 07:11 PM
Mase's Avatar
Default Re: Autotuning question (KOTSEMOTO)
what do you mean by "out of range of a certain AFR" , i think thats incorrect
It looks for a certain voltage, and when its off, it makes small corrections, until the target = the log
but say you are running way way rich, the lowest it will show is 9.0:1 @ 0 volts, it still knows you are running way rich.....etc.
Old Feb 18, 2003 | 09:24 PM
MiraiZ's Avatar
a standalone forum would be nice...hint hint!!
Old Feb 18, 2003 | 09:50 PM
highbrid's Avatar
Default Re: Autotuning question (MiraiZ)
does anyone else have the techedge and have a problem with the techedge display not turning on righ away, i have to wait a real long time for it to read. It only diplays the 10.5 default screen at first for like 15 minutes.
Mase will the o2 gain really change from unit to unit?
also what are your guy's dTP accel fuel set at?
Thanks for all the help guys.
[Modified by highbrid, 11:53 PM 2/18/2003]
Old Feb 18, 2003 | 09:54 PM
boostedsol's Avatar
Try contacting JP at the aem ems forum again.
Old Feb 20, 2003 | 11:19 PM
highbrid's Avatar
i got autotuning to work rather well now. I copied my afr map onto my automapping table and it worked great. However when i get up to load above about 40 it just runs real rich like 9:1 and it doesnt change. Any suggestions?
Old Feb 21, 2003 | 03:23 AM
Mase's Avatar
tune the boost cells by hand, i wouldnt trust the automapping for this
Old Feb 21, 2003 | 07:21 AM
highbrid's Avatar
actually ive got quite a few boost cells tuned by automapping, it just seems like there are those few turd cells that wont change. i used the settings that blkmagic or whatever his name is did on the ems forum and automapping worked 100 times better. I guess I will just tune those cells by hand. Its just hard to guess what raw values to put in, especially when in vtec.
Old Feb 21, 2003 | 08:19 AM
Mase's Avatar
you go through the boost cells very quickly, its hard for the ems to calculate some of them.....if you really wanna tune it w/ automap, boost in fifth, slowly, and keep repeating the cells.
Old Feb 21, 2003 | 08:40 AM
highbrid's Avatar
i was doing the fifth gear pulls, but i just get to certain cells that wont change at all, i set them to like 12.5 or so but they go immediatly down to 9 and stick there.
Boner_Ben
Jun 18, 2006 09:19 AM
boostedlude01
Mar 23, 2005 08:50 PM
MONTCO Si
Aug 16, 2004 07:46 PM
Wo-Nelly
Feb 3, 2004 11:02 PM
Canuk_SiR
Sep 18, 2003 06:41 AM
