removing the oil squirters
Old Feb 17, 2003 | 07:38 PM
SolidSpruce's Avatar
Default removing the oil squirters
ive heard from a few sources that removing the oem oil squirters inside the block is not a problem and is preferred if running turbo, or other oil hungry setups....
that the oil squirters sole purpose is to cool the stock pistons - due to their physical composition, that metal retains too much heat, and thus needs oil splashed on the bottom to help keep things cooler....
but that will silicon/aluminum aftermarket pistons such as JE or SRP, that this heat retention is not a problem with the metals properties, and thus the need for oil squirters is wasted oil pressure that could best be reserved for higher pressure in the crank and head...
i would like to get some outside opinion and debates as to the legitimacy of this tweak...
thanks
Old Feb 17, 2003 | 08:04 PM
rOby's Avatar
Default Re: removing the oil squirters (SolidSpruce)
ive heard teh same
Old Feb 17, 2003 | 08:11 PM
bruthaboost's Avatar
You're understanding is correct. If you want confirmation from other sources, try engine building texts. That's where I find this and most of my info.
97CWITR
Mar 19, 2011 07:27 AM
qpe
Jul 29, 2010 11:37 PM
acrytet70
Aug 18, 2009 07:33 AM
turbo-crx
Mar 3, 2009 10:13 AM
90crxzc
Dec 6, 2003 01:36 PM
