turbo ls i need help no boost
Old Feb 17, 2003 | 09:51 PM
TURBO LS HATCH's Avatar
Default turbo ls i need help no boost
ok guys i have a 96 hatch with a 96 ls swap with a drag gen 3 turbo kit walbro 255 fuel pump an AEM fuel pressure regulater and vortec fmu i had a fuel problem and my boost gauge only read 7 but i had alot of power till it leaned out at 5,000 rpms now i fixed the fuel and the vac now reads 20 but when i get on it, it still feels like its all motr the boost gauge reads 7lbs but im not going anywhere fast could it be my wastegate or the turbo itself i heard my wastegate could be stuck open how can i fix that oh and heres how i have the vac hooked up ok the blow off valve is teed of to the pcv valve hose and the boost gauge is teed of to the break booster and the rest is to my fuel pressure regulater please help this is my first turbo experince so if i did something wrong just tell me i like NOS it was alot easier
Old Feb 17, 2003 | 09:58 PM
T-sohctec's Avatar
Default Re: turbo ls i need help no boost (TURBO LS HATCH)
your problem is you have a shitty management system. your either running hella rich or lean in boost.
does it bog down in boost do you feel a change at all when you spool?
I just realized... are these stock injectors?
[Modified by T-sohctec, 1:58 AM 2/18/2003]
Old Feb 17, 2003 | 10:02 PM
CzanSOHC's Avatar
Default Re: turbo ls i need help no boost (T-sohctec)
lol, welcome to a turbocharged Honda
Old Feb 18, 2003 | 04:26 AM
yes stock injectors and no i dont feel a change when the turbo spools i did but when i teed all that vac to different places i stoped feeling the turbo all togeather
Old Feb 18, 2003 | 07:45 AM
TurbothisLS's Avatar
if the boost gauge reads 7psi and stays there then you are getting boost
if the boost gauge is teed off at the fpr then the engine is seeing boost, if before the throttle body, check your piping and connections for boost leak
if your wastegate was stuck open you would not see boost unless it was a small leak. remove wastegate and check the spring or rev the engine and feel for exhaust gas out of the wg dump tube (with paper or something)
as for fuel:
are u running the FMU?
i would get rid of that and run the AFC hack or standalone
that would solve your fuel issues
Old Feb 18, 2003 | 03:48 PM
Default Re: turbo ls i need help no boost (TurbothisLS)
i found out my problem for no boost the wastegate was stuck open but now it leans out and it reads like 15psi but i know its not 15psi now what could be the problem
Old Feb 18, 2003 | 03:55 PM
b16ahybrid's Avatar
How do you know it's not 15psi? your boost gauge isn't going to read 15psi unless it's actually seeing 15psi....Is your wastegate hooked up properly? what kind is it?
Old Feb 18, 2003 | 04:09 PM
Default Re: turbo ls i need help no boost (b16ahybrid)
i have the wastegate that comes with it the one that sux i forgot the name
Old Feb 18, 2003 | 04:11 PM
93LSivic's Avatar
So where is the inline fuel pump that is supplied in the Drag kit?
It is neccesary!
*EDIT* Dont "T" off of the PCV. You will draw oil vapor into your bov/wastegate.
[Modified by 93LSivic, 8:13 PM 2/18/2003]
Old Feb 18, 2003 | 04:14 PM
i bought an intank fuel pump
Old Feb 18, 2003 | 04:22 PM
b16ahybrid's Avatar
delta gate?
Old Feb 18, 2003 | 04:24 PM
turbod16y8's Avatar
did u ever messed with the timmng? played with the distributer?
Old Feb 18, 2003 | 06:19 PM
Bongnak's Avatar
Default Re: turbo ls i need help no boost (turbod16y8)
need to know too im not boosting also
Old Feb 18, 2003 | 10:23 PM
Default Re: turbo ls i need help no boost (93LSivic)
this goes to 93lscivic u ran 12.71 with street tires what do u have for internals or what ecu r u runing and whats the most boost u can run on a stock ls i mean stock with turbo kit and is it possible to run like 8psi and then a 35 shot NOS dryshot before the intercooler or should i just run more boost like 11psi
Old Feb 19, 2003 | 11:43 AM
93LSivic's Avatar
Dude, before you start runnin 8 psi and a 35 shot I would seriously suggest you get the proper fuel managment. The FMU MUST be used in conjunction with the inline fuel pump supplied to you with the drag kit even though you are using the aftermarket intank pump.
At that time the motor was completly stock w/ turbo. With the exception on hondata and 550 injectors. You will need larger injectors...i would suggest dsm 440's with the afc hack, this is the cheapest and works very well. As far as boost, its all about the tuning, however stock pistons suck *** and the ring lands are known to crack if they see any signs of detonation.
My hondata is for sale by the way.
eGeeHaTcH
Jan 10, 2005 09:32 PM
alpha_1
Jul 30, 2004 11:39 PM
Fired Honda
Jun 30, 2003 08:27 PM
turbod16y8
Mar 23, 2003 04:44 PM
SOHC_power
Oct 30, 2002 10:10 AM
