What hondata? Which to get?
Old Feb 18, 2003 | 08:10 AM
xrtdac
Guest
Posts: n/a
Default What hondata? Which to get?
I have an 1997 obdII Ls integra with a drag gen 3 kit on it. I am needing to go to hondata for reasons not being revealed right now. (its getting a massage)
Anyone know what hondata system I need to run?
I can get a P28 socketed supposivley for a stage 2/3/4/s100/s200 series hondata
and the harness for obd2 to obd1.
Is that what I need or do I need a different socketed ecu?
Old Feb 18, 2003 | 08:17 AM
ekb18c's Avatar
Default Re: What hondata? Which to get? (xrtdac)
If you're not goign to do the tuning yourself and the s100 with boost will be fine for you.
Let me know if you need it. I got it at a good price.
The p28 that is already socketed should be good.
HTH
Old Feb 18, 2003 | 08:30 AM
laughinxxx's Avatar
New User
Default Re: What hondata? Which to get? (ekb18c)
T, the S200 will allow you to pick up a wideband O2, ROM editor, and some other toys and let you autotune your car when ever you want. Personally, I won't be putting new pistons in the car every month or changing out cams constantly, so I'm going to sit with the S100 on a P28. I just can't afford the S200 right now. I don't know your cash flow right now, but if you can get the S200 do it. Then you can tune the rest of our cars on the street. That way we don't have to go to the dyno and drop $300 everytime a new mod gets put on the cars. BTW, I can get P28s for $100-$120 depending on condition.
Old Feb 18, 2003 | 08:38 AM
yellowsub's Avatar
Default Re: What hondata? Which to get? (laughinxxx)
s200 isn't that much more than a s100 so i would just fork over the 50 or so extra bucks and get that.
[Modified by yellowsub, 11:39 AM 2/18/2003]
Old Feb 18, 2003 | 12:02 PM
madman604's Avatar
Default Re: What hondata? Which to get? (yellowsub)
Thats why I got the S200 instead. minimal $ difference.
Old Feb 18, 2003 | 12:27 PM
Diego Boost's Avatar
Default Re: What hondata? Which to get? (Turbo E)
Go s200
Old Feb 19, 2003 | 09:59 AM
xrtdac
Guest
Posts: n/a
Default Re: What hondata? Which to get? (99GSRT)
So I need a:
P28 socketed for S200[although are all the socketings the same for each type anyways??] (anyone got one, I have one guy who wants 150 for his)
S200 hondata
OBD2 to OBD1 harness connector
Old Feb 19, 2003 | 10:03 AM
TurboTegB18c's Avatar
U could also use a p74/75 ecu which is the ls ecu. It might be cheaper then the p28. Paul
Old Feb 19, 2003 | 10:23 AM
xrtdac
Guest
Posts: n/a
Default Re: What hondata? Which to get? (TurboD16Z6)
So I could use my own ECU and just send that to Hondata for socketing?
[Modified by xrtdac, 11:23 AM 2/19/2003]
Old Feb 19, 2003 | 05:09 PM
yellowsub's Avatar
I think you can do that. http://www.hondata.com/ check out the site to be sure.
Old Feb 24, 2003 | 03:35 PM
xrtdac
Guest
Posts: n/a
Does not look like I can use my stock one cause mine is OBD2
Old Feb 24, 2003 | 04:01 PM
LS-T's Avatar
New User
I have a 98 ls
So how much are we looking at for everything needed
I'm looking to replace my Safc fuel system real soon
Hondata s200 $$ ?
OBDII to OBDI harness connector $$?
p28 socketed for s200 $?
is this all i need?
someone please PM me
i have a 98 integra ls t3t4
Old Feb 24, 2003 | 04:36 PM
ski_rebel_3's Avatar
Default Re: What hondata? Which to get? (Armani692)
You are going to need a 255lph intank fuel pump and larger injectors if you are still on your stock ones.
Old Feb 24, 2003 | 05:07 PM
LS-T's Avatar
New User
Default Re: What hondata? Which to get? (ski_rebel_3)
got it already...rc 440's and 255
Old Feb 24, 2003 | 06:42 PM
93LSivic's Avatar
I would suggest the stage 3b. As you can see in my sig that I have exactly what you need ---with the exception of a harness.
Old Mar 3, 2003 | 10:55 AM
xrtdac
Guest
Posts: n/a
Default Re: What hondata? Which to get? (93LSivic)
93LScivic you got PM about that hondata.
SilverCoupeEj8
Engine Management and Tuning
Mar 6, 2011 02:24 PM
ITR32
Jun 23, 2007 09:12 PM
nikko_SOHC
Jul 5, 2006 04:24 AM
TorganFM
Nov 18, 2003 07:52 PM
done
Oct 13, 2002 10:13 PM
