Downpipe bolt...why does it look like this?
Old Feb 19, 2003 | 12:47 PM
B18EG6's Avatar
Default Downpipe bolt...why does it look like this?
I cant seem to find the post....But why did somoene have a downpipe bolt like this?
and why is it better than the original downpipe bolts, and where did they find one to fit the threads?
TIA
Old Feb 19, 2003 | 01:04 PM
AccSIR's Avatar
Default Re: Downpipe bolt...why does it look like this? (B18EG6)
it looks like they designed it that way for easy access.
Old Feb 19, 2003 | 01:05 PM
T-sohctec's Avatar
are you sure that this is a downpipe bolt. Cuz it's going into the back of the block?
does not compute
Old Feb 19, 2003 | 01:08 PM
Tinker219's Avatar
Default Re: Downpipe bolt...why does it look like this? (T-sohctec)
somebody used that bolt, but in a different location, like the DP
I have done something similar, and yes its for easier access...
Old Feb 19, 2003 | 01:54 PM
SiRkid's Avatar
Default Re: Downpipe bolt...why does it look like this? (Tinker219)
st00pids custom dp setup has a bolt like that
Old Feb 19, 2003 | 02:30 PM
B18EG6's Avatar
Default Re: Downpipe bolt...why does it look like this? (SiRkid)
does not compute
shoulda clarified...downpipe bolt that looked very similiar to that one.
awesome. Thank you, I will ask him.
Old Feb 19, 2003 | 03:07 PM
SiRkid's Avatar
i was bored
theres a pic at the top and a couple more at the bottom
https://honda-tech.com/zerothread?id=411335
Old Feb 19, 2003 | 03:49 PM
boostedsol's Avatar
Wow, I have never seen that. Guess you learn many new things here everyday on H-T.
Old Feb 19, 2003 | 04:59 PM
Dancing is Forbidden's Avatar
Default Re: Downpipe bolt...why does it look like this? (boostedsol)
i was going to say that looks like the bolts that are on the intake manifold mount.
Old Feb 19, 2003 | 05:20 PM
@irborne's Avatar
were you referring to this?
the bolt is mainly used for convenience; it easier to work on; that's it.
Old Feb 19, 2003 | 06:00 PM
accordfreak's Avatar
Default Re: Downpipe bolt...why does it look like this? (@irborne)
hmm can you find those bolts at any hardware store??
Old Feb 19, 2003 | 06:15 PM
Tinker219's Avatar
Default Re: Downpipe bolt...why does it look like this? (accordfreak)
might be a specific thing, but you can find a long bolt and put another nut on to simulate that style bolt. If it has to be a specific length , then you could tack weld the nut so that it stays stationary when you screw everything in.
Old Feb 19, 2003 | 07:10 PM
blufke's Avatar
relating to dp bolts. on a maxrev dp what do you use for the space where a bolt should go but is an extremely tight fit? the bottom bolt of the 4.
Old Feb 19, 2003 | 07:11 PM
Tinker219's Avatar
actually you could use two nuts on and lock them together....im not so retarded afterall
Old Feb 19, 2003 | 09:11 PM
Foozball26's Avatar
for the max rev downpipe you put a stud into the turbo and use a nut to secure it. You can use any stud from the head of a honda, as well as the nut.
those long bolts like shown in the picture are honda factory bolts that are on the exahaust, they are just brand new and dont have the spring on it like the exahust system has. at least thats what they appear to be theres a few other bolts in the engine bay that look like that as well.
Old Feb 20, 2003 | 07:00 AM
blufke's Avatar
Default Re: Downpipe bolt...why does it look like this? (foozball-26)
where is a good place to get just a few honda head studs/nuts?
Old Feb 20, 2003 | 07:58 AM
SiRkid's Avatar
Default Re: Downpipe bolt...why does it look like this? (blufke)
the dealer? ahahaha
Old Feb 20, 2003 | 01:35 PM
Foozball26's Avatar
junkyard or dealer, or find someone in the middle of thier swap and nab a couple
Old Feb 20, 2003 | 02:18 PM
XES's Avatar
XES
The clearance on my downpipe was so tight that I had the bolt placed through the bottom right flange hole before the downpipe was welded to the flange. Now I can do it up (just like a normal bolt)...but I also can never remove the bolt completely.
Old Feb 21, 2003 | 06:20 AM
st00pid's Avatar
Default Re: Downpipe bolt...why does it look like this? (XES)
One of the first things I do when I do a swap on one of my cars is yank that bracket off.. Its very annoying to work around, so I had a few of these bolts laying around.. Im always complaining about having to take the DP off whenever we need to.. so I used this bolt to make life easier. and so far its working.
jason
Old Apr 13, 2003 | 03:01 AM
blufke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foozball-26 &raquo;</TD></TR><TR><TD CLASS="quote">for the max rev downpipe you put a stud into the turbo and use a nut to secure it. You can use any stud from the head of a honda, as well as the nut.
those long bolts like shown in the picture are honda factory bolts that are on the exahaust, they are just brand new and dont have the spring on it like the exahust system has. at least thats what they appear to be theres a few other bolts in the engine bay that look like that as well.</TD></TR></TABLE>
bringing this back, but you mean the studs for either the intake or exhaust mani? anyone know where to get those exhaust bolts(aside from swiping it from mine or someone elses exhaust, and not paying nasty dealer prices.
$ISELLTOU4LESS$
Feb 11, 2007 11:12 AM
flangemastermike
May 31, 2006 02:20 PM
brent_G
Sep 8, 2005 03:19 PM
kenbdSi
Oct 27, 2002 10:03 AM
