550 injectors or larger???????
Old Feb 18, 2003 | 03:54 PM
boosted_zc's Avatar
Default 550 injectors or larger???????
Well my fully built ZC is in the home stretch and i'm focusing on my fuel management recently. I originally was thinking 550's would be suffient to feed my engine, just like some opinions or some mathmatical way of of figuring the correct flow rate. My setup will be a t3/t4 boosting between 15-20 psi, i may also go up to 25 psi tops. I'll be running either Hondata or Zdyne and a walbro high flow fuel pump. I believe that's all you'll need to know to make an informed opinion. If you need any more info plz post it. Any info will be greatly appreciated. Thanks
Old Feb 18, 2003 | 04:01 PM
ill_take_one's Avatar
Default Re: 550 injectors or larger??????? (boosted_zc)
Do a search, there is A TON of info if you do the search right. I just looked for the same topic the other day.
If you plan on going all the way up to 25psi...you'll have to go bigger than the 550cc's..
Old Feb 18, 2003 | 05:13 PM
CRVRX's Avatar
Default Re: 550 injectors or larger??????? (ill_take_one)
I have maxed out 450cc's at 286WHP , I would say 550cc's would be about done at 330WHP.
That should give you an idea.
drvfast
Oct 13, 2003 07:14 PM
Anubyss
May 16, 2003 05:12 AM
boosted_zc
Feb 18, 2003 04:14 PM
