350-400whp for a 2.4l
Re: 350-400whp for a 2.4l (Paul_Vang)
Well, I would suggest the T3/T04E .82 A/R Stage III /.60 A/R 60 Trim only becasue the KA24DE has more displacement and can flow more air than a 1.8L or 2.0L. It will also insure that you make 400 whp whereas you *MAY* fall short with the .63 A/R turbine housing.
What is this crap?
Re: 350-400whp for a 2.4l (Dee)
The AR.63 would be better because you would get more horsepower under the curve.
i rode in a 240sx with the ka24 last nite. damn thing pulls nice from 2000rpm. i wouldnt put too big a turbo on this motor and make it all top end. the thing has a nice drivable midrange. I'd put a smaller turbo on it and make that midrange even more powerful for gunning out of turns, but thats just me. i dont know much about the ka24 engine geometry but it might not be the best candidate for top end power (drag racing). i guess that would go to the sr20det which is engineered for boost.
Re: 350-400whp for a 2.4l (falconGSR)
Well, I had teh .82 A/R on my SR2DE for quite sometime. I started boosting around 3500 and hit full boost ~ 4500 rpms. Keep in mind that this was with a smaller displacement 2.0L. I have seen may KA24's with the .63 A/R and for some reason, they can't get over the 330-340 whp range. The head does not flow well enough to make that kind of power with the .63 housing.
Re: 350-400whp for a 2.4l (TurbochargedSER)
You also need to consider the redline of the KA engine. A jump to the AR.82 will move the torque band up and kill the street worthiness. PEAK horsepower means absolutely nothing if it takes 3 weeks to get to that point. Power under the curve is a better choice if you are not planning to ride the rev limiter everytime you get in the car. If this is a dedicated weekend warrior by all means use the larger housing but that's a waste of money if you aren't going to increase the engines breathing and revving capabilities.
thanks for the replys guys, and yes its for a Ka24e.... figured i'd ask here becuase you guys know your stuff. im also goin to have a mild port work on the head.
about the talk about the ar. im not worried about the peak hp, i would like a nice usable 300-350ish whp. 400 would be nice but i wont complain with anything over 300. the redline would be 7.5k thanks again
D.Dappa
11-22-2004 04:54 AM
legendboy
11-14-2002 06:50 PM
