Building a turbo kit - check list
Old Feb 18, 2003 | 09:48 AM
Xscream's Avatar
Default Building a turbo kit - check list
I am working with a local guy building a turbo kit for my car. The way his comes its a turbo, waist gate, blow off vavle and 321 stainless manifold. I need to make sure though that I have everything... Here is what I have
T3/T4 Turbo
Manifold
Tial Waist Gate
HKS BOV
Piping
Cuplers
IC
SAFC
12.1 FMU
oil lines and fittings (with bung for pan)
Fuel Pump
Is there anything else that I am missing that I will need to make this thing run right? Thanks guys!
Old Feb 18, 2003 | 09:50 AM
swrdply400mrelay's Avatar
Default Re: Building a turbo kit - check list (Xscream)
ditch FMU and get 440cc/450cc injectors. Look up the AFC hack, much better than an FMU setup.
Old Feb 18, 2003 | 09:54 AM
Xscream's Avatar
Default Re: Building a turbo kit - check list (swrdply400mrelay)
I am trying to work out a deal for a Honda Data, trying to get it up and running, I will worry about that crap later... I'm not a big hack fan - I love stand alone
Old Feb 18, 2003 | 10:14 AM
Trac226's Avatar
You'll want to get some specs on that T3/T4 that will fit your engine and hp goals. And just some help on the terminology for future reference: It's Tial waste gate, couplers, and Hondata. You will need larger injectors as well, visit www.hondata.com to start your research.
Old Feb 19, 2003 | 06:30 AM
Xscream's Avatar
Default Re: Building a turbo kit - check list (Trac226)
Hey thanks, I'm a old Gm guy so I'm use to LT1 edit and tuner cat. Thanks for the info
Old Feb 19, 2003 | 06:40 AM
B20-T's Avatar
440cc injectors,hondata or vafc,and save some money for tuning afterwards
Old Feb 19, 2003 | 06:41 AM
TurbothisLS's Avatar
make sure your manifold and turbo will fit in that space in front of the block and that you will not have to use pusher fans. other than that, downpipe, wastegate dump tube and looks like you've got it
Old Feb 19, 2003 | 06:58 AM
mamaboy's Avatar
street or race? oh and you forgot your exhaust system 2.5" or 3". well the question now is your power goals. injectors and hondata for sure.
[Modified by mamaboy, 3:59 PM 2/19/2003]
Old Feb 19, 2003 | 06:54 PM
hollaback6's Avatar
what is the afc hack?
Old Feb 19, 2003 | 08:18 PM
Cowboy's Avatar
how much did it cost you and which parts were used/new?
i'm thinking of building a kit too
Old Feb 19, 2003 | 08:39 PM
crzsomang's Avatar
EDIT: ok, TurbothisLS already said it...
[Modified by crzsomang, 5:40 AM 2/20/2003]
[Modified by crzsomang, 5:41 AM 2/20/2003]
Old Feb 19, 2003 | 09:35 PM
Trac226's Avatar
Default Re: Building a turbo kit - check list (Cowboy)
From used parts found here on h-t:
Manifold, T3/T4, waste gate, intercooler = $840
DP, IC piping, BOV, oil lines = $500
Thermal 3" = $400
450cc, Resistor Box, clips = $95
Running total at = $1835
Just need some fuel management and a dumptube and I think i'll be set.
Spoon_Si-R
Aug 26, 2006 05:34 PM
socal_brandon_
May 3, 2004 07:42 PM
AirWaveGT
Mar 19, 2004 09:20 PM
