light flywheel helps?
Old Sep 21, 2004 | 12:47 PM
joboost13's Avatar
Default light flywheel helps?
i got a ls teg, and i am boosting soon. But i have a b16 transmision on it. I still have my ls tranny, but it sucks for accelaration. I was wondering if any 1 had any experince wit a light flywheel on the tranny. That way i still have the top speed, but wit fast accelaration as well. All coments appreciated .
Old Sep 21, 2004 | 12:54 PM
joboost13's Avatar
Default Re: light flywheel helps? (joboost13)
no body gona help me out? Com'on uall, nobody tried this?
Old Sep 21, 2004 | 01:03 PM
1bad-eg's Avatar
I have a fidanza flywheel in my setup and love it.
Old Sep 21, 2004 | 03:50 PM
vtekstorm's Avatar
Default Re: light flywheel helps? (1bad-eg)
i got a act 12lb flywheel works great not to heavy not too light eiether
Old Sep 21, 2004 | 05:03 PM
ogabudiah's Avatar
Default Re: light flywheel helps? (vtekstorm)
I have a B18A1 with the fidanza 7 pound flywheel, and my mid range to top end is worse than stock, not enough rotational mass.
Old Sep 21, 2004 | 05:47 PM
94dxt's Avatar
Default Re: light flywheel helps? (ogabudiah)
I've got a Zex 9lb chromally
Old Sep 21, 2004 | 06:12 PM
joboost13's Avatar
Default Re: light flywheel helps? (94dxt)
so it accelarates faster, but u loose power? How does that work with boost? If i put the ls tranny back on wit a 9 pound fly wheel on 10 pounds of boost, with a t/3 i would loose power?
Old Sep 21, 2004 | 06:14 PM
94dxt's Avatar
you should gain hp and torque by adding the flyweel
Old Sep 21, 2004 | 07:15 PM
adseguy's Avatar
The light flywheel allows the engine to rev up quicker, but it also revs back down faster so unless you do ultra fast shifting all the time then its to no use in boost since your RPMs drop down more.
Old Sep 22, 2004 | 03:40 PM
ogabudiah's Avatar
Default Re: light flywheel helps? (adseguy)
It will be even harder to launch with boost.
Old Sep 22, 2004 | 04:52 PM
shermanyang's Avatar
i've got an ACT Prolite and it makes a great difference in acceleration. honestly...how much time do you actually spend in neutral when shifting?!? maybe 1/10th of a second which will hardly drop your rpms when shifting during a race. also...how do you lose midrange to highend power with a light flywheel? there is less mass for your motor to rotate so therefore freeing more power, even though many times it will not even show on a dyno.
Old Sep 22, 2004 | 06:21 PM
ILuvJDMITR's Avatar
Default Re: light flywheel helps? (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">i've got an ACT Prolite and it makes a great difference in acceleration. honestly...how much time do you actually spend in neutral when shifting?!? maybe 1/10th of a second which will hardly drop your rpms when shifting during a race. also...how do you lose midrange to highend power with a light flywheel? there is less mass for your motor to rotate so therefore freeing more power, even though many times it will not even show on a dyno.</TD></TR></TABLE>
he was refering to gearing differances in te two trannys... LS Vs. B16
IMO, run the LS tranny with the ACT streetlite flywheel (12lb) keep a little rotational mass, not as much vibration to the drivetrain, and you keep good gearing up top. I understand turbos decel faster than NA, so keeping a little mass would be good for you. I think alot will agree with my position
D16SohcVtec
Jul 22, 2008 06:39 PM
IntegR
Oct 25, 2006 05:36 PM
oneslodx
May 4, 2004 08:36 AM
VSM EXtasy
Feb 27, 2003 05:38 AM
EvilIntegrationLS
Dec 17, 2002 08:54 PM
