need advice on head build for boost
Old Sep 18, 2004 | 09:47 AM
95gsrturbo's Avatar
Default need advice on head build for boost
I m looking to rebuild my GSR head soon. I have 2 broken exhaust manifold studs one retapped to standard size and too many exhaust leaks....
To reduce downtime i plan on buying a bare GSR head, P&P then all new internals
I would like a 9K redline to stay in boost a bit longer than i am currently if you think that my bottom end can handle it (rebuilt abuot 40K miles ago with SRP (9.5:1 and Eagle rods, all new honda seals, bearings etc)
I was debating with ITR OEM parts all new (valves, springs, retainers, guides, etc)
or to go with SI valves company
I thought abuot ferrea but the cost is way too high and i would like longevity out of this also. any suggestions are GREAT
thansk
Old Sep 18, 2004 | 11:44 AM
DSF's Avatar
DSF
Default Re: need advice on head build for boost (95gsrturbo)
Well, pushing 9k out of ITR parts that were meant for 8.6k might be hurting the longevity you're after. Ferrea's parts really aren't that expensive for what you get.
Old Sep 18, 2004 | 11:47 AM
boosted92's Avatar
Default Re: need advice on head build for boost (DSF)
Run skunk2 springs and retainers, it's not that expensive and good insurance.
Old Sep 18, 2004 | 12:10 PM
TeamCracka's Avatar
Default Re: need advice on head build for boost (boosted92)
Avoid Ti-retainers.
Old Sep 18, 2004 | 01:27 PM
95gsrturbo's Avatar
Default Re: need advice on head build for boost (TeamCracka)
thanks guys, i was going to avoid Ti retainers because of the 35K rebuild issue i ve heard so much about
i know i need steel retainers but what abuot Ti springs, how long will they usually last. 35K miles can be just over a year for me.
Also i know many people who run the ITR head over 9K constantly not advised i know but what do you guys think
from the comparison stuff Skunk SUX, ferrea makes good stuff but for the price they dont last long
Old Sep 19, 2004 | 10:51 AM
95gsrturbo's Avatar
ttt
Old Sep 19, 2004 | 10:54 AM
SiKid86's Avatar
use a b16 head, try sunk2 springs and retainers. Get the si head p&P and call it a day.
Old Sep 19, 2004 | 11:04 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: need advice on head build for boost (SiKid86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiKid86 &raquo;</TD></TR><TR><TD CLASS="quote">use a b16 head, try sunk2 springs and retainers. Get the si head p&P and call it a day.</TD></TR></TABLE>
LOL...i love how people swear that the b16 head ported is better than a ported gsr..
Old Sep 19, 2004 | 11:19 AM
SiR831's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamCracka &raquo;</TD></TR><TR><TD CLASS="quote">Avoid Ti-retainers.</TD></TR></TABLE>
had some that were chipping due to the rocker arms making contact.
Old Sep 22, 2004 | 07:19 PM
95gsrturbo's Avatar
Default Re: need advice on head build for boost (SiR831)
yeah i also dont understand how the b16 vs b18c1 is better, if ported
most people used to use the b16 because of easier access...
besides i dont want to have to switch the intake mani-- i love the dual runners for now because i drive lots of highway miles, - better gas and good throttle resp when needed.
Old Sep 25, 2004 | 10:21 AM
95gsrturbo's Avatar
bump need more info guys... how much should i ned up spending total for the head?
Old Sep 28, 2004 | 06:26 PM
DeadLock23's Avatar
hey M, I think the OEM is your best bet, look around if you have time, as long as the car runs for now, dont boost too much lol, and did you ever get that cooling problem looked at?
Old Sep 28, 2004 | 07:15 PM
turbo*s2k's Avatar
Default Re: (DeadLock23)
I'm running an ITR head with RM springs, and retainers. Stock ITR intake/exhaust valves. 9k redline... no problems so far. Just stick with your stock head, and upgrade the springs, and retainers.
Old Sep 28, 2004 | 09:55 PM
95gsrturbo's Avatar
Default Re: (TurboChrgd_Civic)
well stock head needs to be swapped because i have two broken exhaust mani studs... therefore tons of exhaust leak which keep my turbo from properly spooling and sound like ***
so the head gets swapped with a rebuilt one--
I DO NOT WANT TO CHANGE THE head for another- because i will have to change intake mani, TB and then charge piping, etc, too much hassle-
sticking to gsr head with built internals
really looking toward OEM
I just found Omni power thru K-tellers site. looks like decent stuff but need more info on them....
anyone have any?
Old Sep 30, 2004 | 01:56 PM
95gsrturbo's Avatar
Default Re: (95gsrturbo)
bump--- need know what parts ot use ASAP
thanks
Old Sep 30, 2004 | 02:02 PM
jDMJeRk's Avatar
port polish
stock valve size
supertech valve train (black nitrate coding, dished) (500 shipped; talk to earl or camp1320.com)
gsr cams are good for temp (save yoyr money for now)....
hth gl
JdmTypeRdc2
Aug 17, 2009 06:41 AM
turboteg90
Mar 9, 2008 07:43 PM
SoTexDC2
Oct 5, 2006 10:46 AM
Red99CivicSi
Jan 28, 2003 07:58 PM
