Turbo Start ?'s
Old Sep 19, 2004 | 08:43 AM
aalb1's Avatar
Default Turbo Start ?'s
Hey I just started my car after installing my turbo and have a few questions:
How do you know if there is a vacuum leak?
What should your boost reading be at idle?
At Idle my wastegate vacuum lines get pinched shut by vacuum: is this normmal?
How much do I need to adjust my HKS BOV?
Thanks in advance
Old Sep 19, 2004 | 09:05 AM
fattymatty's Avatar
Default Re: Turbo Start ?'s (aalb1)
wrong forum, try the forced induction one...
Old Sep 19, 2004 | 12:48 PM
aalb1's Avatar
Default Re: Turbo Start ?'s (fattymatty)
oops my bad!
Old Sep 19, 2004 | 01:34 PM
aalb1's Avatar
Anyone?
Old Sep 19, 2004 | 01:38 PM
BROOD's Avatar
your idle will be higher than normal, if you try to drive it under low load it will act up...you'll know trust me
At idle you should read a vacuum instead of a positive boost psi
where are your lines hooked to for the vacuum signal? what kind of tubing?
Donno, is it not functioning?
Old Sep 19, 2004 | 01:46 PM
aalb1's Avatar
Default Re: Turbo Start ?'s (BROOD)
I have this 6mm tubing going to a vacuum manifold to the wastegate then from the wastegate to my boost controll valve then back to the vacum manifold.
My BOV screw is very loose and still flutters.
Old Sep 19, 2004 | 02:02 PM
toolowsol's Avatar
you need a better vacuum signal for your BOV, try the brake booster. Vacuum pressure at idle should be between 19-22 inHG And use stronger tubing for your wastegate line, I run my wastegate directly off the turbo compressor housing, try that.
Old Sep 19, 2004 | 02:10 PM
aalb1's Avatar
Default Re: Turbo Start ?'s (toolowsol)
yea I got this red Pep Boys hose. where can I get the right hose?
Now what if I only run 8-9 lbs of vacuum at idle what does that mean?
Old Sep 19, 2004 | 02:14 PM
aalb1's Avatar
Wait I am running 20lbs of vacuum at idle. For some reason the greddy boost controller is reading 9.5lbs
b18-c-rx
Aug 2, 2005 12:06 AM
lkailburn
Jul 27, 2005 10:36 AM
Battle Mike
Jan 6, 2005 05:45 PM
TurboTegB18c
Sep 12, 2004 10:58 AM
servion
Jan 17, 2002 07:13 PM
