Fuel pressure problem HELP!!! ASAP
Old Sep 20, 2004 | 07:21 PM
kaedingracer3's Avatar
Default Fuel pressure problem w/jrsc HELP!!! ASAP
I am having a major problem. My fuel pressure is 40 psi at idle but when i get on it the psi only rises to 55-60 psi under boost and the motor runs extremly lean. I Have a brand new fuel filter and pump. Heres my setup.
D16a6 with darton flange sleeves
scat rods
JE pistons 8.3-1 compression
ported and polished ports and chambers
swirl polish valves
isky springs
crane cam Duration intake:232 Exhaust: 234
Jrsc with boost upgrade 10-11 psi
Short ram intake
AEM fuel rail
stosk injectors
Airmass header
2.5" exhaust with apexi N1
Intank walbro pump
Fuel psi gauge coming off of rail
Modified by kaedingracer3 at 4:32 AM 9/21/2004
Old Sep 20, 2004 | 07:53 PM
Zeppelin's Avatar
Default Re: Fuel pressure problem w/jrsc HELP!!! ASAP (kaedingracer3)
Are you using the stock JRSC fuel pressure regulator? If so, with the stock injectors you will not have enough fuel even at 100psi of fuel pressure to run rich enough. I am not sure why your fuel pressure is so low.
Old Sep 20, 2004 | 07:59 PM
Default Re: Fuel pressure problem w/jrsc HELP!!! ASAP (Zeppelin)
What size injectors should i run?
Old Sep 21, 2004 | 08:14 PM
CRX_1.8T's Avatar
A. K. it's me, Tree. basically everything fuel system related has been looked at. lets just get it over with and go to DNR in hayward next week... i need to talk to the dude anyways about tuning my turbo engine.
LSEGHATCH
Nov 4, 2005 12:45 PM
kaedingracer3
Oct 15, 2004 08:23 AM
kaedingracer3
Sep 22, 2004 03:14 PM
kaedingracer3
Sep 21, 2004 10:01 PM
zseeanz
Apr 5, 2004 07:48 AM
