Lowering Compression using headgasket???
Old Sep 18, 2004 | 03:52 AM
f1 vtec's Avatar
Default Lowering Compression using headgasket???**resurected**
Is it possible to lower the compression down to 9.01-9.5.1 using a thicker headgasket on a b16a2 and would it be practical for around 320whp because id rather not mess with pistons and rods until next year in the meantime i can concentrate on the tuning side hondata etc, im gonna be running a t3/t4e .60 trim and hoping for around 300whp at around 15psi
If it is possible what headgasket will take me there?? anyone tried it whats your experiences??
Modified by f1 vtec at 11:37 AM 4/23/2007
Modified by f1 vtec at 11:44 AM 4/23/2007
Old Sep 18, 2004 | 04:49 AM
DSF's Avatar
DSF
Default Re: Lowering Compression using headgasket??? (f1 vtec)
No personal experience, but have seen it done plenty of times...
http://www.inlinepro.com/catal...d=124
Old Sep 18, 2004 | 07:24 AM
TheShodan's Avatar
Moderator
Default Re: Lowering Compression using headgasket??? (DSF)
Yes. This approach has been done before..
Old Sep 18, 2004 | 07:33 AM
f1 vtec's Avatar
hmm so it is an option tempting, the question is how much power will i be able to run with this setup and what gasket will get me there.
any experiences etc
thanks
Old Sep 19, 2004 | 05:49 AM
f1 vtec's Avatar
any experiences with lowering compression with headgaskets?
Old Sep 19, 2004 | 06:27 AM
95GSRTT
Guest
Posts: n/a
roflmao 300 dollars for a head gasket. THats jus ******* stupid.
Old Sep 19, 2004 | 06:30 AM
TurboJesse
Guest
Posts: n/a
Default Re: Lowering Compression using headgasket??? (95GSRTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">roflmao 300 dollars for a head gasket. THats jus ******* stupid.</TD></TR></TABLE>
considering the center section is re useable its not too bad..The setup works well. I used to run it. Quite a few stock motors making 350-400whp with it.
Old Sep 19, 2004 | 07:25 AM
spike's Avatar
Default Re: Lowering Compression using headgasket??? (Mpir3)
if you just run 12-13 psi on stock headgasket tuned you should be close to the same power level as 15psi with the thicker headgasket... just the tq #'s wont be there, correct?
Old Sep 19, 2004 | 07:27 AM
_entropy's Avatar
Default Re: Lowering Compression using headgasket??? (spike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spike &raquo;</TD></TR><TR><TD CLASS="quote">if you just run 12-13 psi on stock headgasket tuned you should be close to the same power level as 15psi with the thicker headgasket... just the tq #'s wont be there, correct?</TD></TR></TABLE>
The power loss you see going from 10.2:1 to 9:1 is not going to be as great as 2 or 3 pounds of boost.
Old Sep 19, 2004 | 07:41 AM
spike's Avatar
Default Re: Lowering Compression using headgasket??? (@lbert)
I would be very surpised if a head gasket alone could bring it down from 10.2 to 9.. i was thinking more along the lines of 9.5:1.
Old Sep 19, 2004 | 08:21 AM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spike &raquo;</TD></TR><TR><TD CLASS="quote">I would be very surpised if a head gasket alone could bring it down from 10.2 to 9.. i was thinking more along the lines of 9.5:1.</TD></TR></TABLE>
2mm will drop it a full point
Old Sep 19, 2004 | 08:26 AM
YashiMotors's Avatar
what about the time belt, when putting on those thick head gaskets?
Old Sep 19, 2004 | 08:29 AM
TurboJesse
Guest
Posts: n/a
Default Re: Lowering Compression using headgasket??? (John_Doe)
you have to make up for it with cam gears...Usually advancing the intake and exhaust cams 2 deg works.
Old Sep 19, 2004 | 08:31 AM
maybe a stupid question ....but how thick is a stock ITR b18C6 headgasket ?
Old Sep 19, 2004 | 08:57 AM
_entropy's Avatar
A 2MM headgasket will take a B16 to 9:1 compression. A 3MM gasket will take it to 8.25:1.
Old Sep 19, 2004 | 09:20 AM
f1 vtec's Avatar
where can i get a 2mm headgasket or is it possible to use 2 oem headgaskets??
how much power will stock internals last with lowering compression like this??
any experienced ppl anybody else tried it
Old Sep 19, 2004 | 10:40 AM
TurboJesse
Guest
Posts: n/a
my motor has been together for about a year @ 315whp on pump gas. You could prolly safely push 350-375 on race gas.
Old Sep 19, 2004 | 12:23 PM
f1 vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">my motor has been together for about a year @ 315whp on pump gas. You could prolly safely push 350-375 on race gas.</TD></TR></TABLE>
what gasket/s u running? whats your setup
Old Sep 19, 2004 | 12:28 PM
TurboJesse
Guest
Posts: n/a
Inline pro 2mm gasket and ARP's. I sold the car a month ago..
Old Sep 19, 2004 | 04:51 PM
spike's Avatar
Completely stock head and bottom end?
Old Sep 19, 2004 | 06:38 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spike &raquo;</TD></TR><TR><TD CLASS="quote">Completely stock head and bottom end? </TD></TR></TABLE>
umm....i painted the block
Old Sep 20, 2004 | 10:55 AM
f1 vtec's Avatar
thats interesting i may use this method temoprarily until i dont get pistons etc
Old Sep 29, 2004 | 01:56 PM
f1 vtec's Avatar
any more experiences with this
Old Sep 29, 2004 | 03:04 PM
XxRoCkMaNxNEOxX's Avatar
which is better the cometic or the inlinepro?
Old Sep 29, 2004 | 05:36 PM
LostSolVTEC's Avatar
Default Re: Lowering Compression using headgasket??? (XxRoCkMaNxNEOxX)
from what i was told, the cometics now only drop the comp about .2 or .3 points, they used to make a 2mm gasket but don't anymore.
