MAP sensor
Old Sep 19, 2004 | 02:52 PM
b16 matt's Avatar
Default MAP sensor
What map sensors can you use with the hondata. I have a grand national map sensor will that work?
Old Sep 19, 2004 | 04:58 PM
EM1 MIKE's Avatar
Default Re: MAP sensor (b16matt)
You planning on boosting more than 10-11psi?
Old Sep 20, 2004 | 04:23 PM
b16 matt's Avatar
Default Re: MAP sensor (EM1 MIKE)
well I have a built engine that would be a severe waste if not. I am going for about 16psi. Yes i know the stock map sensor with hondata will read up to 11psi.
Old Sep 20, 2004 | 04:24 PM
lanojp1's Avatar
GM 3 Bar Map Sensor
sets you back about 90 bucks
Old Sep 20, 2004 | 04:44 PM
b16 matt's Avatar
Default Re: (lanojp1)
Nope 46 dollars http://www.partsamerica.com/Pa...Set=A This one is 3 bar the Grand Nat one is only 2.
Old Sep 20, 2004 | 04:47 PM
mekkis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16matt &raquo;</TD></TR><TR><TD CLASS="quote">well I have a built engine that would be a severe waste if not. I am going for about 16psi. Yes i know the stock map sensor with hondata will read up to 11psi.</TD></TR></TABLE>
Stock MAP sensor doesn't read to 11 psi, Hondata misinformed you.
GM 2 bar (off everything GM forced induction except the 89 turbo trans am) reads 14.3 psig maximum, you want GM 3 bar.
Old Sep 20, 2004 | 05:38 PM
EGturbocoupe's Avatar
what's the wiring graph to wire in a GM map sensor
Old Sep 20, 2004 | 05:41 PM
iiilgsrlll's Avatar
Default Re: MAP sensor (mekkis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mekkis &raquo;</TD></TR><TR><TD CLASS="quote">
According to AEM EMS literature max reading is 10.94 psi. Can anyone verify if that's correct/incorrect?
Old Sep 20, 2004 | 05:48 PM
b16 matt's Avatar
Default Re: MAP sensor (EGturbocoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGturbocoupe &raquo;</TD></TR><TR><TD CLASS="quote">what's the wiring graph to wire in a GM map sensor</TD></TR></TABLE> http://www.hondata.com/3barinstall.html
Old Sep 20, 2004 | 06:08 PM
mekkis's Avatar
Default Re: MAP sensor (iiilgsrlll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiilgsrlll &raquo;</TD></TR><TR><TD CLASS="quote">
According to AEM EMS literature max reading is 10.94 psi. Can anyone verify if that's correct/incorrect?</TD></TR></TABLE>
Never seen better than 10.6 for 92+ era MAP sensors.
85-91 net 9.25 psig tops.
Old Sep 21, 2004 | 12:12 AM
b16 matt's Avatar
Default Re: (rota92)
I chopped mine off of my dad's 88 chevy celebrity. The harness that is.
Old Sep 21, 2004 | 01:33 AM
ATS*Mark's Avatar
OG triple OG
GM 2 bar (off everything GM forced induction except the 89 turbo trans am) reads 14.3 psig maximum, you want GM 3 bar.</TD></TR></TABLE>
im running 12.5 on my stock map sensor . you are misinformed.
Old Sep 21, 2004 | 06:26 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: MAP sensor (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">
im running 12.5 on my stock map sensor . you are misinformed.</TD></TR></TABLE>
Well your MAP sensor cant tell you running 12.5! Only about 11, did Mase tune your car?
If you dont belive me than bust out a volt meter and see what you come up with
Old Sep 21, 2004 | 07:00 AM
ScottEK's Avatar
Default Re: MAP sensor (si2die4)
OBD-0 stock map stops at about .65 kg/cm^2 which is about 9.5psi.
champLSinteg
Jul 19, 2008 11:21 PM
dc4teg95
Mar 9, 2008 11:59 PM
beak
Jul 9, 2006 01:28 PM
lucidvtec
Jul 11, 2005 11:51 PM
DubyaAye
Apr 28, 2004 10:22 PM
