What is the correct thing to do...
Old Sep 19, 2004 | 01:55 AM
Bambooseven's Avatar
Default What is the correct thing to do...
What is the correct thing to do with the breather tube that comes off your valve cover and into your intake (N/A) when you do a turbo setup? I just put one of those little APC type breather filter deals on there, I assume it is not a good idea to be putting boost through that line.
it has been running w/ the filter on there for a year now, I was just wondering if there is a more correct way to do it, maybe an inline check valve?
TIA
Old Sep 19, 2004 | 06:55 AM
Boosted2K's Avatar
Default Re: What is the correct thing to do... (Bambooseven)
Put the APC filter on the valve cover (6.3 WHP gain)
Buy this
http://www.theoldone.com/components/breather/
Old Sep 19, 2004 | 02:22 PM
Default Re: What is the correct thing to do... (Boosted2K)
I have a catch can on my PCV valve, what do I do for the valve cover line?
Old Sep 19, 2004 | 04:45 PM
btw I don't think it makes a difference, but this is a D16y8
Old Sep 20, 2004 | 05:40 AM
Boosted2K's Avatar
The pcv valve will close under boost and pressurize the crank case
Old Sep 20, 2004 | 05:53 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bambooseven &raquo;</TD></TR><TR><TD CLASS="quote">I have a catch can on my PCV valve, what do I do for the valve cover line?</TD></TR></TABLE>
What kind of catch can setup do you have? Run it to a can on its own with a filter, or run it to the can you already have depending on your setup
If you want, just leave it alone. The filter will need cleaned like every oil change.
Old Sep 20, 2004 | 07:15 AM
SOHC_MShue's Avatar
man i've been running the same filter **** on there too for a while now. The correct way though would just be to put a catch can on there.
Old Sep 20, 2004 | 07:17 AM
SOHC_MShue's Avatar
Default Re: What is the correct thing to do... (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted2K &raquo;</TD></TR><TR><TD CLASS="quote">Put the APC filter on the valve cover (6.3 WHP gain)
Buy this
http://www.theoldone.com/components/breather/</TD></TR></TABLE>
i thought you can't really use that on a d-series unless you tap an extra fitting in the back of the block or something.
Old Sep 20, 2004 | 11:44 PM
I'd really like to know what I should do in this case, I can't see the filter on the valve cover as the right answer, but I am not sure I should be Y'ing my valve cover line into the same line coming from my PCV.
any insight?
Old Sep 21, 2004 | 12:30 AM
AF-b16a1's Avatar
same here i just have a cheap breather on that crankcase...how do you hook up the catch can to the pcv valve (y7 y8 are the pcv valves teh same?)?
Old Sep 21, 2004 | 12:34 AM
crispydee's Avatar
Default Re: (AF-b16a1)
This has two nice diagrams. Im in the process of doing this so any other ideas please
http://www.beesandgoats.com/bo...l#PCV
Old Sep 21, 2004 | 06:25 AM
Overblown-Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bambooseven &raquo;</TD></TR><TR><TD CLASS="quote">I'd really like to know what I should do in this case, I can't see the filter on the valve cover as the right answer, but I am not sure I should be Y'ing my valve cover line into the same line coming from my PCV.
any insight?</TD></TR></TABLE>
The right thing to do would be run it to a tube before the turbo so it sucks all that back in like stock.. Its an emissions thing. letting it the way it is now won't hurt anything.
Old Sep 22, 2004 | 06:35 AM
crispydee's Avatar
Default Re: What is the correct thing to do... (Overblown-Teg)
Im in the uk and the legal side is not a problem. Is it ok to remove the pipe from the pcv valve and run it straight to a catch can which blows off under the car. Have a filter on the valve cover.
Old Sep 22, 2004 | 10:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Overblown-Teg &raquo;</TD></TR><TR><TD CLASS="quote">
The right thing to do would be run it to a tube before the turbo so it sucks all that back in like stock.. </TD></TR></TABLE>
so say you don't have an intake tube before the turbo?
Old Sep 22, 2004 | 10:51 AM
raene's Avatar
Route it to the exhaust with a flat cut tube. That will create lower pressure and have a suction effect.
fryman
Apr 3, 2013 04:12 AM
Black R
Jan 25, 2010 07:18 PM
vtec.dc2
Oct 15, 2006 10:19 AM
Johnny_Rocket
Apr 11, 2005 05:26 AM
spencer00si
Sep 6, 2002 01:46 PM
