atpturbo cutout
Old Sep 21, 2004 | 12:45 PM
chitownrida's Avatar
Default atpturbo cutout
vacuum operated.. hmmm........ i might have to try this out
DC2's Avatar
DC2
Default Re: atpturbo cutout (chitownrida)
Yes, me too.
Old Sep 21, 2004 | 12:48 PM
igo4bmx's Avatar
that would only open during full boost.... what about the rest of the powerband?
Old Sep 21, 2004 | 12:52 PM
DC2's Avatar
DC2
Default Re: (igo4bmx)
It wouldn't matter in most applications.
Old Sep 21, 2004 | 12:56 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (DC2)
Kinda stupid if you ask me. It would be better to run a QTP so you spool faster rather than just lose restriction once you're there .
Old Sep 21, 2004 | 01:08 PM
donkiman's Avatar
im not experienced with e-cutouts. what are the advantage to them? i relize you could run a stock looking muffler and then have the ecutout open at full throttle... is this correct?
Old Sep 21, 2004 | 01:09 PM
DC2's Avatar
DC2
Default Re: (DC2)
I doubt the lag time would be that bad to hinder spool-up.
Old Sep 21, 2004 | 01:10 PM
DC2's Avatar
DC2
Default Re: atpturbo cutout (donkiman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman &raquo;</TD></TR><TR><TD CLASS="quote">im not experienced with e-cutouts. what are the advantage to them? i relize you could run a stock looking muffler and then have the ecutout open at full throttle... is this correct?</TD></TR></TABLE>
Most e-cutouts are activated by the user's toggle switch.
Old Sep 21, 2004 | 01:14 PM
TwoK4drSi's Avatar
Default Re: atpturbo cutout (DC2)
Wouldn't it close in between shifts? Woundn't that make it more prone to break faster?
Old Sep 29, 2004 | 04:00 PM
prostreetonline's Avatar
This is interesting.
Anyone tried this?
Old Sep 29, 2004 | 04:10 PM
Blindstuff's Avatar
Default Re: atpturbo cutout (TwoK4drSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoK4drSi &raquo;</TD></TR><TR><TD CLASS="quote">Wouldn't it close in between shifts? Woundn't that make it more prone to break faster?</TD></TR></TABLE>
I would guess so.
Edit: Would it just open once it sees 1 psi of boost or what?
Old Sep 29, 2004 | 04:21 PM
Zackyt's Avatar
looks kinda like a big wastegate huh
Old Sep 29, 2004 | 05:27 PM
Muckman's Avatar
Moderator in Chief
I think the idea would be to hook up a solenoid inline with the vac line so you would have control over when it actually opened.
Old Sep 29, 2004 | 05:31 PM
racinskittle's Avatar
Default Re: atpturbo cutout (Muckman)
It prollly opens when there's boost. Kinda neat. Wonder how well it works.
Old Sep 29, 2004 | 06:05 PM
BluSiBoy's Avatar
Default Re: atpturbo cutout (racinskittle)
I'd preffer the E-cutout that yuo open up with a button.
Old Sep 29, 2004 | 06:42 PM
BEEYOND's Avatar
Default Re: atpturbo cutout (BluSiBoy)
Dude just get the wastegate to open at 1-2psi...
stop crying people...
heard you can chose your wastegate spring....
hahah
Old Sep 29, 2004 | 06:44 PM
BEEYOND's Avatar
Default Re: atpturbo cutout (nicholashang87)
however the button activation may be a better choice overall!!!!
Old Sep 29, 2004 | 07:01 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicholashang87 &raquo;</TD></TR><TR><TD CLASS="quote">Dude just get the wastegate to open at 1-2psi...
hahah</TD></TR></TABLE>
you can hook up a boost controller to it too, so that it doesnt open at all, or it opens at X psi..
Old Sep 29, 2004 | 07:06 PM
B18Flip's Avatar
Default Re: atpturbo cutout (J337_UNIT)
looks like a good unit, I wonder if the actuator is set for a certain psi or if you can adjust it. I've heard that the electric ones have a lot of problems, like the electric motor failing....and this gets rid of that problem
Old Sep 29, 2004 | 07:21 PM
wHOAlly's Avatar
Default Re: atpturbo cutout (B18Flip)
the people saying this is stupid and a ecutout would work better obviously dunno ****
e-cutout open vs closed, it like running 2 completely different setups, therfore needing 2 completely different maps if you want the car to run decent, so either your gonna be tuned with the ecutout closed, or open, so it will either run like **** when its open cuz you are tuned when its closed, or vice versa.
with the atp cutout, its proportinate to your VAC, runs off the same basis as your wastegate, therfore the results are reproducible, meaning it can be tuned properly, normal driving it probably doesnt open, but when u go WOT, it would open up, which is perfect, atleast thats the theory, i dont see why it wouldnt work, its identical to a wastegate setup.
Old Sep 29, 2004 | 08:58 PM
Triscuit's Avatar
Awesome find man
Old Sep 29, 2004 | 09:00 PM
buda18's Avatar
Default Re: (Ronin EG6)
looks cool
but i am loving my open 3" DP!!!
"sounds mean"
"sounds like a V8"
Old Sep 29, 2004 | 09:20 PM
Zackyt's Avatar
Default Re: (buda18)
does anyome know how big this is, im guessing 3" but i didnt see anything on the site?
Old Sep 29, 2004 | 09:31 PM
Default Re: (Zackyt)
yeah i have a 2.5-3" open downpipe and YEAH!! lol it does sounda really ******* mean. Sounds like a diesel. But i've heard problems with the cutouts too. I'd rather run this than a cutout. Looks a lot more reliable. Also he's right, you'll only need 1 tune.
Old Sep 30, 2004 | 04:47 AM
PrettyLude's Avatar
what's the price on the unit?
