Oil in coolant burning oil.
I got oil in my coolant and i burn oil i think. I changed my head gasket and it didnt fix the problem. What else could it be and how could i fix it?
Re: (m R g S r)
b16 9:1 ductile iron sleaves eagle rods. No i didnt replace the o-ring damn do you think this could be the problem. I definetly did it in the correct order, but the psi on the bolts might be wrong what is it on the arp's. I couldnt get a straight answer from arp so i did it to oem specs. Where is that oil ring you speak of?
Modified by b16matt at 8:55 PM 9/20/2004
Re: (b16matt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16matt »</TD></TR><TR><TD CLASS="quote">b16 9:1 ductile iron sleaves eagle rods. No i didnt replace the o-ring damn do you think this could be the problem. I definetly did it in the correct order, but the psi on the bolts might be wrong what is it on the arp's. I couldnt get a straight answer from arp so i did it to oem specs. Where is that oil ring you speak of?
Modified by b16matt at 8:55 PM 9/20/2004</TD></TR></TABLE>
On the block's mating surface, toward the back of the block, is where the oil control orifice is located. If you didn't replace its o-ring, you could have 50+psi of oil going to your HG. The oil could be finding it's way to coolant and mixing.
Re: (turbosi03)
Well I did a leak down test and i have leakage between 3 and 4. So the good news is i found the problem the bad news is it could be a number of reasons.
Dropped wall head gasket, etc. I guess ill just tear it appart this weekend and find out. Wish me luck
98civc123
23
09-08-2021 08:14 PM
