Arp head studs worth it? or just hype?
Old Sep 20, 2004 | 07:14 PM
lkailburn's Avatar
Default Arp head studs worth it? or just hype?
hey guys i'm daily driving a 97 civic dx and i will be boosted this spring. i've got almost everything now but i'm gonna wait for winter to pass. i picked up a y8 long block but am just gonna swap the head pending it does good on leak down and surface tests. if i do this i figured i should get a new headgasket and everyone recommends arp head studs when boosted.
so: is it just hype or will i run into issues when i'm boosted?
ill be doing a basic hmt setup with a cx mani, 13g turbo, 450's, uber, 5" jrc fmic etc. nothin big but quick and peppy for sure.
thanks i appreciate it,
Luke
Old Sep 20, 2004 | 07:27 PM
sporkcrx's Avatar
Default Re: Arp head studs worth it? or just hype? (lkailburn)
They'll do you fine
Old Sep 20, 2004 | 07:49 PM
Rod.'s Avatar
Default Re: Arp head studs worth it? or just hype? (sporkcrx)
if you pulled the head off might as well put arp in. Why go back stock...
Old Sep 20, 2004 | 08:18 PM
lkailburn's Avatar
well just asking if its worth it. theres no sense in wasting 80-100 bucks on them if they don't do anything.
but i've heard that boosted d's are notorious for headlift and the arp head studs supposedly will never allow that to happen.
any other opinions?
Old Sep 20, 2004 | 08:30 PM
5thgen's Avatar
Default Re: (lkailburn)
Its also not a bad idea to replace the head bolts anyway....and through honda they are around $8 a piece. A little more money and you have arp head studs.
like someone else said, why not?.
Old Sep 20, 2004 | 08:39 PM
eHoward's Avatar
ARP isn't hype.
Old Sep 20, 2004 | 08:45 PM
11psiTurboSI's Avatar
Default Re: (5thgen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgen &raquo;</TD></TR><TR><TD CLASS="quote">Its also not a bad idea to replace the head bolts anyway....and through honda they are around $8 a piece. A little more money and you have arp head studs.
like someone else said, why not?.</TD></TR></TABLE>
Honda head bolts don't stretch so why would you need to buy new ones from the dealer??? I reused mine in my b16a2 and I've boost up to 18psi with no problems! I say you should be fine without them, I was going to get them but they were back ordered for a month and I needed my car out of my shop so I used my stock head bolts.... It's extra insurance, but if you not going to boost more then 8-10psi I wouldn't spend the extra money just my 2 cents
Old Sep 20, 2004 | 08:46 PM
jDMJeRk's Avatar
if you are looking to get a ARP set id pay a little bit more for the AEBS ones, i searched and found less problems with them
hth
Old Sep 20, 2004 | 08:48 PM
Rookie101's Avatar
Default Re: (jdmjerk)
if you don't get them don't go turbo....
that's all bro!!!
Old Sep 20, 2004 | 08:54 PM
lkailburn's Avatar
^^ personal experience rookie? or just passing on what you've heard?
more comments plz
Old Sep 20, 2004 | 08:55 PM
SOHC_MShue's Avatar
they are worth it!
Old Sep 20, 2004 | 09:21 PM
AFFIRMED's Avatar
go with either aebs or arp dont use stock
Old Sep 20, 2004 | 09:28 PM
SiKid86's Avatar
Default Re: (AFFIRMED)
i'd think he would be cool as long as he don't put alot of boost on it wouldn't you? I mean at 7-8 psi stock should do you fine. but if you start throwin on more boost yeah the would be the way to go.
Old Sep 20, 2004 | 09:37 PM
AFFIRMED's Avatar
Ok if you go stock and then wanna turn up the boost then your going to say I should have spent the extra money and bought arp or aebs studs.Then your buying a new head gasket ect.
Do it wright the first time it will save you money in the long run.
Old Sep 21, 2004 | 05:13 AM
lkailburn's Avatar
ok, if the head turns out good. i will get the arp tuds ontop of a new gasket.
if i don't do the headswap..i will try to get my *** to do it but it seems like a pain if i don't already have the head off.
thanks for the comments
-Luke
Old Sep 21, 2004 | 05:17 AM
Joseph Davis's Avatar
Default Re: (9psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">
Honda head bolts don't stretch </TD></TR></TABLE>
I thought torque-to-yield meant they stretched?
Also, local Honda wants $15/per for headbolts. ARP are cheaper.
Old Sep 21, 2004 | 06:13 AM
GRTechnologies's Avatar
Default Re: (J. Davis)
I use stock bolts in my h22's
Old Sep 21, 2004 | 01:26 PM
rioninja's Avatar
One of the reasons i went with arp headstuds, is the fact that they stay in the block.
The block IS aluminum after all, and fixing stripped or otherwise damaged
threads in my block is something i would rather avoid.
Old Sep 21, 2004 | 07:36 PM
honda13typer's Avatar
Default Re: Arp head studs worth it? or just hype? (rioninja)
its better to be safe than sorry spend a couple more dollars here an there and ull save money in the long run. this goes for every car part i buy.
Old Sep 22, 2004 | 07:15 AM
mchuang's Avatar
I would buy them because I seen a case when A guy was unbolting his head to replace a blown headgasket and one of the threads stripped so he couldnt bolt the head back on. If he would have had arps then he wouldn't have had to bother with the threads just loosen the nuts. 100 bucks is nothing compared to having to get another block because of a stripped thread
Old Sep 22, 2004 | 07:34 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lkailburn &raquo;</TD></TR><TR><TD CLASS="quote">is it just hype?
arp bolts are good for what they are made for. you can reuse them, used them twice already.. good product
Old Sep 22, 2004 | 07:40 AM
npcanibus3's Avatar
Default Re: Arp head studs worth it? or just hype? (vtec.dc2)
if you have the money and time to put down some arp, go for it. I wouldnt worry too much other than that since those d-series rods are most likely going to first since they're twigs!
Old Sep 22, 2004 | 07:45 AM
jdmjason's Avatar
Default Re: Arp head studs worth it? or just hype? (npcanibus3)
arp headstuds are worth their weight in gold
Old Sep 27, 2004 | 08:21 PM
GWInquisitor14's Avatar
Default Re: Arp head studs worth it? or just hype? (jdmjason)
i just bought em for my head swap, they came today...i didn't even realize they are reused able....wow thats even cooler.
Old Sep 27, 2004 | 09:53 PM
JFK78's Avatar
Yes D-series are notorious for lifting under boost. A FEW people get away with 8+psi on stock headbolts, but that is the exception.
I have had the head lift on the last 6 D-series I've dealt with.
With the ARP's, never had one lift again. I will never, ever boost a D without putting ARP's in.
Do yourself a HUGE favor and put them in now since the head is off.
