boosted f22 or h23
Old Sep 19, 2004 | 11:36 AM
4thgenlude's Avatar
Default boosted f22 or h23
ive got an f22 and an h23 and im planning on boosting one of them this winter, my question is, whichone would you use?
f22= Iron Sleeves + low comp, but its Sohc and there fore less power to begin with but it will hold more boost
h23= Dohc + Not too high comp , which is goood for low end power, but it doesnt have iron sleeves and the compression isnt the best for boost, so i wont be able to run high psi , but its got more power from the get go
I was looking into putin the h23 head on the f22, but after searching a little bit It seems like it s not gonna work
thanks
-Charlie
Old Sep 19, 2004 | 11:50 AM
sohcvtec1995's Avatar
Default Re: boosted f22 or h23 (4thgenlude)
IMO i would do the F22. just make a list of pros and cons and go from there
Old Sep 19, 2004 | 11:56 AM
4thgenlude's Avatar
Default Re: boosted f22 or h23 (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">IMO i would do the F22. just make a list of pros and cons and go from there</TD></TR></TABLE>
thats what I tried doing here, just a few,
anyone want to add any?
thanks
Old Sep 19, 2004 | 01:16 PM
b_ron007's Avatar
i believe the 2 are the same except for the bore. well at least.......bore/stroke and compression are the same for the F23
Old Sep 19, 2004 | 01:17 PM
b_ron007's Avatar
btw......f-series engines are dime a dozen! boost the F, theres not a whole lot power difference between the 2 engines. what, maybe 10hp
Old Sep 19, 2004 | 01:36 PM
dropt's Avatar
Default Re: (b_ron007)
~20hp 10lb tq.
Old Sep 21, 2004 | 07:36 PM
4thgenlude's Avatar
Default Re: (dropt)
stock for stock theres a decent amount of power difference, but i think ive decided to use the f22 block and run the h23 head and IM, and boost with a 14b, and then later maybe around next winter, I can buy an h22 crank and throw on some forged rods and pistons, without having to resleeve the block , plus if I break something on the block f22 are cheap, very cheap
Old Sep 21, 2004 | 07:59 PM
xrunner86x's Avatar
the f likes the boost, and its cheap, id go with that
Old Sep 21, 2004 | 08:08 PM
jmal1919's Avatar
Default Re: (4thgenlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenlude &raquo;</TD></TR><TR><TD CLASS="quote">stock for stock theres a decent amount of power difference, but i think ive decided to use the f22 block and run the h23 head and IM, and boost with a 14b, and then later maybe around next winter, I can buy an h22 crank and throw on some forged rods and pistons, without having to resleeve the block , plus if I break something on the block f22 are cheap, very cheap </TD></TR></TABLE>
u should just boost the f22 as is. It will love u for it. save the money involved with running the h23 head on the f22 and put it towards ur build of the h23 or just cash for a bad day
Old Sep 21, 2004 | 08:54 PM
blown_LS's Avatar
Default Re: (jmal1919)
You are going to boost with 14b? I'll fall on its *** after 5k but you are deffinetly going to have plenty of low end torque.
Just my 02.
Old Sep 22, 2004 | 04:27 PM
4thgenlude's Avatar
Default Re: (blown_LS)
yeah, itll a cheap setup, but ive already got every thing the h23 head swap, exept the aebs head studs. so im definetely get gonna do that, i know that the 14b is little but i know someone with a 14b on an h22 and its stays pretty strong untill redline, im not looking for crazy #'s
Hharrishonda
Jun 18, 2008 11:25 AM
tron-R
Feb 25, 2008 04:19 AM
h23acc0rd
Mar 14, 2007 04:33 PM
thegeorge613
Nov 6, 2005 09:05 PM
