crankcase breather filter?
Old Sep 21, 2004 | 09:07 AM
djnikko's Avatar
Default crankcase breather filter?
What does the majority of people do with their crank case breather, direct it back into the charge pipes or vent it? or is either ok? I seem to be getting alot of smoke coming out and its coming thru the firewall on the car!!! at the mo its vented.
Thanks in advance
Old Sep 21, 2004 | 09:15 AM
m R g S r's Avatar
Default Re: crankcase breather filter? (djnikko)
Do NOT vent it into a charge pipe, because it will become pressurized under boost. If you have an intake tube between the inlet on the turbo and the air filter, tap that, it will suck the vapor away from the valve cover.
USDM 4G VTEC's Avatar
use a filter and vent it
or rout it to a catch can, and the other line to the back of the block to the catch can also, and vent the can to the atmosphere
Old Sep 21, 2004 | 09:18 AM
inspyral's Avatar
You can route it from the valve cover to a catch can and then back to the inlet pipe going into the turbo. Or just go form the valve cover to the intake pipe going into the turbo. If you're getting excess smoke, you may have another problem. I never had much smoke if any when I was running a breather filter.
Old Sep 21, 2004 | 09:32 AM
Ben Huynh's Avatar
Catch can or breather would be your best choice.
Catch can
http://www.importparts.com/sho...=2720
Breather
http://www.importparts.com/sho...=1676
Old Sep 21, 2004 | 01:17 PM
RyanEJ8's Avatar
Default Re: crankcase breather filter? (ben@importparts.com)
My understanding was that the breather wouldn't work on the block, because there is no vacuum to pull the blow-by vapors out.
Anyone have more info on this?
Old Sep 21, 2004 | 01:31 PM
raene's Avatar
Default Re: crankcase breather filter? (RyanCivic2000)
The crankcase under WOT will have positive pressure for the same reason the valvecover does under WOT. So it'll work
Old Sep 21, 2004 | 01:38 PM
Rod.'s Avatar
Default Re: crankcase breather filter? (raene)
I just have a hose coming off of it and dumping towards the ground. That is what I researched from different people
Old Sep 21, 2004 | 01:55 PM
Ben Huynh's Avatar
Default Re: crankcase breather filter? (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">I just have a hose coming off of it and dumping towards the ground. That is what I researched from different people</TD></TR></TABLE>
LOL that's not the most environmentally correct way to do it but it works.
Old Sep 21, 2004 | 03:24 PM
Rod.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com &raquo;</TD></TR><TR><TD CLASS="quote">
LOL that's not the most environmentally correct way to do it but it works. </TD></TR></TABLE>
lol, i already have a endyn catch can/pcv coming off my block
Old Sep 22, 2004 | 07:44 AM
RyanEJ8's Avatar
Ben, the link to the breather doesn't work for me.
Old Sep 22, 2004 | 08:47 AM
Ben Huynh's Avatar
If the link doesn't work for you, go to the site and search part number ACA-IN-H112.
digital sol
Aug 22, 2005 09:47 PM
Prelude91siT
Jan 1, 2004 10:42 AM
BoostedSi
Nov 25, 2003 12:35 PM
redtegger03
Jun 25, 2003 10:41 AM
ELUD THS
Sep 8, 2002 04:33 PM
