8psi LS turbo, LEAN at 4,000 rpm and up!!! PLEASE HELP!
Hello there, I just finished my turbo setup, I am using an S-AFC, 450cc injectors and a T28 turbo boostin 8psi, with a pretty good sized spearco intercooler ofcourse.. anyways, Boost comes in at about 2,800rpm, and continues to build up till about 4 thousand full boost, The car is pulling hard from 2,800 to 4,000 and then the car bogs down and a/f gauge is LEAN LEAN! Do I need to raise the Fuel pressure or something?? is that why?? or what do you think is wrong?? I am using my stock fuel pressure regulator.. why is the car bogging down and the a/f gauge FULL LEAN!?? got my safc set to 35% accross the rpm range...
thanks,
Mark
Modified by MarkAngelo at 7:24 AM 9/20/2004
Modified by MarkAngelo at 7:25 AM 9/20/2004
thanks,
Mark
i ♥ my honda
Global Mod
Global Mod
Re: 8psi LS turbo, LEAN at 4,000 rpm and up!!! PLEASE HELP! (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">What a/f did you use? </TD></TR></TABLE>
I think he ment gauge ?
If you are going off a narrow band A/F gauge that uses you stock sensor or even one that come with a sensor like the greddy one than it is NOT going to help you TUNE your engine. You NEED a WIDEBAND
You also proly have a bad stock sensor
Re: 8psi LS turbo, LEAN at 4,000 rpm and up!!! PLEASE HELP! (SOHC_MShue)
yeah, but a christmas-tree guage running lean is blow-motor lean.
I'd try richening up your AFC a bunch. 5-8% maybe? That's what it's there for you know... The AFC hack isn't about a flat percentage as much as a flat AFR
Re: 8psi LS turbo, LEAN at 4,000 rpm and up!!! PLEASE HELP! (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar »</TD></TR><TR><TD CLASS="quote">The AFC hack isn't about a flat percentage as much as a flat AFR</TD></TR></TABLE>
whole9
21
06-21-2007 02:06 AM
MarkAngelo
09-23-2004 05:51 AM
