Engine Break-in with turbo...?
Old Sep 19, 2004 | 08:10 PM
djwest24's Avatar
Default Engine Break-in with turbo...?
sorry, if the post has been covered, but searching didnt gimme a definitive answer...
i just rebuilt my single cam, all stock internals, but new rings and bearings...
can i break it in with the turbo? the reason tht i wanna do this is, i dont have the stock exhaust mani anymore, and my exhaust is custom fabbed to mate with the downpipe, so i gotta change a lotta stuff to break-in NA. can i just break it in with the turbo, but keep the rpm's low, so i dont boost too much??
Old Sep 19, 2004 | 08:19 PM
Muckman's Avatar
Moderator in Chief
Default Re: Engine Break-in with turbo...? (quicksilver17981)
Some break em in with boost and there probably isnt a technical problem with that. However I prefer to break em in NA because theres usualy something you forgot or something loose or something wrong/broken and its better to work out the kinks without 20 lbs of boost.
Old Sep 19, 2004 | 09:11 PM
greebler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver17981 &raquo;</TD></TR><TR><TD CLASS="quote">. can i just break it in with the turbo, but keep the rpm's low, so i dont boost too much??</TD></TR></TABLE>
Keeping the RPM low means you don't spool the turbo, and keeps the pressure in the cylinders down. I would say if you just rebuit it and installed a turbo, do the usual 700 miles breakin. If not a even 1000 miles, just to be safe.
Old Sep 19, 2004 | 09:13 PM
Rod.'s Avatar
Default Re: Engine Break-in with turbo...? (greebler)
break it in on the dyno
Old Sep 19, 2004 | 09:45 PM
crispydee's Avatar
Can you just turn the boost right down it you have run it in.
Old Sep 20, 2004 | 02:53 AM
Trip's Avatar
Default Re: Engine Break-in with turbo...? (crispydee)
I would boost around 5 or so psi, as long as it is followed with a little time in deep vacuum. That's what I did, It helps to seat the rings a little actually.
Old Sep 20, 2004 | 05:07 AM
LostSolVTEC's Avatar
Default Re: Engine Break-in with turbo...? (Trip)
just pull the spring on ur wastegate so u don't spool the turbo and break it in driving around
there are 2 ways to seat the rings...check it out
http://www.superhonda.com/foru...71032
Old Sep 20, 2004 | 05:41 AM
TheShodan's Avatar
Moderator
Breaking in with boost is o.k., as long as you keep it minimal and keep the rpms kinda low as you break it in for 800-1000 miles.
Old Sep 20, 2004 | 07:12 AM
djwest24's Avatar
Default Re: (TheShodan)
thanks for the comments guys...i'll do it with the turbo, and just make sure i dont get too pedal happy...
jeremiah87
Jun 30, 2007 06:11 AM
Cractos
Apr 23, 2004 12:22 PM
hotboi850
Aug 30, 2003 08:59 AM
OKSolSi
May 20, 2002 04:31 PM
