PLX Wideband question (datalogging)
Old Sep 19, 2004 | 06:23 PM
MiKeAhOwSkI's Avatar
Default PLX Wideband question (datalogging)
Hey, I'm tryin to hook up a PLX M-500 (wireless datalogging version) to my Civic and can't figure out how to do the datalogging part at all!
There's the datalogging harness with the 6 wires blue,green,red,white,brown,black
2 for speed signals (measures the frequency of signal pulses)
4 for analog signals (measures the voltage of a signal)
the manual doesn't go into much more detail, and I don't know where to connect these wires at all.
I guess I'm hoping someone who has put this in their OBD-1 honda will know what to do. Thanks for any insight.
Old Sep 19, 2004 | 06:30 PM
Eluzion's Avatar
Default Re: PLX Wideband question (MiKeAhOwSkI)
You hook them up to whatever you want to datalog.
RPM's, Coolant Temp, MAP, etc.
You need the voltage conversions though and set it up with the PLX datalogging software.
I can't help you much with that though cuz I use Uberdata.
Old Sep 19, 2004 | 06:34 PM
Default Re: PLX Wideband question (Eluzion)
okay, that helps a bit, but what would I hook up RPM to? one of the 4 analog signal or one of the 2 speed signal wires? How do I tell the difference?
Old Sep 19, 2004 | 07:44 PM
slim9300's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiKeAhOwSkI &raquo;</TD></TR><TR><TD CLASS="quote">okay, that helps a bit, but what would I hook up RPM to? one of the 4 analog signal or one of the 2 speed signal wires? How do I tell the difference?
The #1 or 2 speed sensor wires. The unit should automatically calibrate as long as you select 4 cycle for the motor selection. This option must be accessed through the software on your labtop.
Old Sep 20, 2004 | 04:31 PM
Eluzion's Avatar
Default Re: PLX Wideband question (slim9300)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slim9300 &raquo;</TD></TR><TR><TD CLASS="quote">The #1 or 2 speed sensor wires. The unit should automatically calibrate as long as you select 4 cycle for the motor selection. This option must be accessed through the software on your labtop.</TD></TR></TABLE>
What he said. I could never get it to log properly in the PLX software though. It would keep going from the correct RPM reading to like 28 back and fourth, making it impossible to use. *shrug*
Old Sep 21, 2004 | 06:45 PM
XDEep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eluzion &raquo;</TD></TR><TR><TD CLASS="quote">
What he said. I could never get it to log properly in the PLX software though. It would keep going from the correct RPM reading to like 28 back and fourth, making it impossible to use. *shrug*</TD></TR></TABLE>
is this a bug? im about to get the m-500
mikej94civex
Jul 11, 2010 04:18 PM
djgruesome
Jul 3, 2006 01:37 AM
blowbyu24
Nov 14, 2005 07:31 PM
Frozen E
Dec 28, 2004 10:07 AM
T25 civic
Oct 2, 2002 12:03 PM
