d16z6 missing under boost
Old Sep 20, 2004 | 07:55 PM
sohcturbocoupe's Avatar
Default d16z6 missing under boost
right when it hits 1psi at around half throtle but after it gets past one or two psi it will smooth back out already checked timing, changed cap, rotor button, map sensor, plugs,wires. Is it possible for the missing link to go bad it's a synapse and i'm running a z6 with the apexi kit if you would just let me know what you think it could be
Thanks
josh
Old Sep 20, 2004 | 08:00 PM
StreetRacin101's Avatar
Default Re: d16z6 missing under boost (sohcturbocoupe)
Check the gapping on your plugs, sounds like at first they may be blowing out.
Old Sep 20, 2004 | 09:12 PM
Default Re: d16z6 missing under boost (StreetRacin101)
there gapped at 40
Old Sep 21, 2004 | 06:15 AM
EKhothatch's Avatar
Thats sounds about right. Try gapping them closer and see what you get.
Maybe too much fuel.
J Spec Sol
Aug 17, 2009 05:07 PM
dkrex001
Oct 3, 2006 04:55 PM
abmerop18
Jun 2, 2006 05:35 PM
ShinnCo
Mar 15, 2005 02:47 PM
sohcvtec1995
Jan 29, 2005 05:28 PM
