traction problems ! i need help?
Old Sep 19, 2004 | 10:19 AM
hotasscivic's Avatar
Default traction problems ! i need help?
ok heres the deal, to make a long story short i have daily driven 95 civic hatch with a fully built type r motor in it with 10.1 arias pistons and crower rods. . it makes a lil over 400 hp at 14 psi. i have a gsr tranny with a kazz lsd . my turbo is a sc61 with the to4s compressor housing with a apexi afc-r boost controller . anyhow my problem is whenever i hit boost my car pulls to the left and the right real bad is this normal? i mean it feels like its outta control. my suspension is just some ground control coilovers with stock struts. i mean i have read about traction bars but will they help my problem? any one have any suggestions to help cure my problem im really confused? any help would be greatly appreciated thanks
Old Sep 19, 2004 | 02:18 PM
Default Re: traction problems ! i need help? (hotasscivic)
damn nobody im the only person with this prob?
Old Sep 19, 2004 | 02:33 PM
Bailhatch's Avatar
Maybe the front control arm bushings are getting sloppy. My car definatly went straighter once I replaced mine.
If your spinning the whole time it might be the car just following the crown in the road or bad front toe out might do the same thing so an alignment could be needed as well.
Old Sep 19, 2004 | 05:35 PM
Default Re: traction problems ! i need help? (Bailhatch)
ok ill try that first thanks a lot for your help
Old Sep 20, 2004 | 06:20 AM
White Smoke's Avatar
i my honda
Global Mod
NO that is normal My car pulls all over the road
First get LSD then traction bars, it will help
Old Sep 20, 2004 | 07:18 AM
Spoold_R's Avatar
New User
full-race traction bars solve all. I running 410 whp on 15psi on my Type R and it stays as straight as an arrow.
adizzlejdm
Jan 24, 2010 08:18 PM
Javcolin
Suspension & Brakes
Aug 10, 2008 08:01 AM
Sinner
Jan 10, 2004 01:32 PM
