will HONDATA work with a VX ECU?
Old Sep 21, 2004 | 01:24 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default will HONDATA work with a VX ECU?
im looking into getting HONDATA for my hatch. i have a custom manifold using a T25. and ide like to use HONDATA for managment. but will my ECU accept hondata?
i think its a P07.. not sure but i know its D15Z1. 92 VX.
Old Sep 21, 2004 | 01:42 PM
nsxmatt's Avatar
Default Re: will HONDATA work with a VX ECU? (Built B16A)
Yes, it can be socketed or chipped like a p28.
Old Sep 21, 2004 | 01:48 PM
Joseph Davis's Avatar
Default Re: will HONDATA work with a VX ECU? (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it can be socketed or chipped like a p28.</TD></TR></TABLE>
Yet, at the same time, no. It won't work with Hyundaidata.
Old Sep 29, 2004 | 07:15 AM
R-Toyz.com's Avatar
Default Re: will HONDATA work with a VX ECU? (J. Davis)
Unless hondata has a basemap that works with the vx ECU, it wont work...it can be socketed though...but thats about it.
Old Sep 29, 2004 | 07:39 AM
blundar's Avatar
actually, I believe it CAN be made to work. Talk to Vernon from RaVer motorsports - he's running one on his turbo H22 I believe.
Old Sep 29, 2004 | 08:47 AM
Patron's Avatar
Have you guys seen the chipset on the P07? It is entirely different than the P28, P06, or the P74/75. Not only is the board different, the VX has a five wire o2, which could be converted of course, but it's not the same as the others.
Old Sep 29, 2004 | 09:01 AM
nsxmatt's Avatar
Default Re: (ptran13)
I'm not sure on how it works but I do know they can be chipped like any p28. I didn't know there was a difference in running Hondata with one though.
Old Sep 29, 2004 | 09:27 AM
Default Re: (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">actually, I believe it CAN be made to work. Talk to Vernon from RaVer motorsports - he's running one on his turbo H22 I believe.</TD></TR></TABLE>
I suspect he tweaked the P07 code, then, because the second MCU that controls the WBO2 keeps polling the main processor with interrupts which freaks it out when chipped with normal OBD1 Civic/Integra code. Runs odd, intermittant VTEC, etc.
Then again, this is Vernon. He probably found some hardware trick... again.
But, yeah, sux for Hyundaidata.
Old Sep 29, 2004 | 09:41 AM
Finest's Avatar
Default Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">
But, yeah, sux for Hyundaidata.</TD></TR></TABLE>
Wait, I'm lost. What??
Old Sep 29, 2004 | 11:24 AM
Built B16A's Avatar
well.. i don't have a local Hondata dealer within 60 miles, so i think its out the window.. i talked to the local tuner, and he said, since im only going 6-7 PSI, i can get away with a FPR and a VAFC. so i think thats the way im going to go.
Old Sep 29, 2004 | 11:31 AM
R-Toyz.com's Avatar
how about running uberdata?
Old Sep 29, 2004 | 03:12 PM
Default Re: (rtzcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">
Wait, I'm lost. What?? </TD></TR></TABLE>
Reread the thread, perfectly intelligible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtzcom &raquo;</TD></TR><TR><TD CLASS="quote">how about running uberdata?</TD></TR></TABLE>
Nope, same exact conflicts with Ubercrap. Where do you think I draw my Hyundaidata conclusions from? Never been wrong either, because the codebase is 99% the same because it is 99% stock Honda code for both Hyundaidata and Ubercrap.
Old Sep 29, 2004 | 04:28 PM
2muchPSI's Avatar
as far as I know the VX(po7) ecu is different than the p05 and p28, and can't be used for uberdata
Old Sep 29, 2004 | 05:18 PM
PHiZ's Avatar
Default Re: (2muchPSI)
I've heard that some work, and some don't. Depending on board revision.
However, I defer to J.Davis's judgment.
-PHiZ
Old Sep 29, 2004 | 06:05 PM
HYBRID_H@TCH's Avatar
Default Re: (PHiZ)
some VX ecu's have 4 wire o2's and some have 5 wire o2's..Iam currently running a 4 wire VX ecu on a 500+ whp civic VX with hondata and a fully built gsr engine..yes it works on some VX ecu's.
Old Sep 29, 2004 | 06:56 PM
I've never seen a 4 wire P07. I have six of the 5 wire sort - they get plugs yanked to build pass thru harnesses.
Old Sep 30, 2004 | 03:51 AM
my buddy has one in his VX..and yes I did check it and it is infact a P07..
Old Sep 30, 2004 | 06:39 AM
R-Toyz.com's Avatar
Nope, same exact conflicts with Ubercrap. Where do you think I draw my Hyundaidata conclusions from? Never been wrong either, because the codebase is 99% the same because it is 99% stock Honda code for both Hyundaidata and Ubercrap.</TD></TR></TABLE>
I know...but I was giving him a cheaper option (actually a free option) since he stated that there weren't any dealers or tuners of honDUHta in his area.
I also think James (HRT) was dabbing into the VX ECU hardware. No news from that little project. We've all been busy I tried toying around with a P07 with a couple of tweaked basemaps a couple of months ago, ended up with a solid CEL each time, but the car ran fine...surprisingly.
What years did the 4 wire VX come out? Always thought they were the 5 wire 02 type. Could it be a spawn of a P27 ECU?
Old Sep 30, 2004 | 07:50 AM
nsxmatt's Avatar
Default Re: (99Hybrid_Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">my buddy has one in his VX..and yes I did check it and it is infact a P07..</TD></TR></TABLE>
I did some checking here at work and in fact in 94-95 there was two options for exhaust manifolds and o2 sensors one being a 4-wire.
The part number for the 4-wire o2 P07 ecu should be 37820-P07-L02. The 5-wire ecu should be a 37820-P07-A01. Either that or the other way around but the 5-wire ecu is over $1000 and the other one is only $700.
Modified by nsxmatt at 11:08 AM 9/30/2004
AzN_Flava
Engine Management and Tuning
Sep 15, 2017 10:33 PM
thirsk66
Feb 2, 2015 10:41 AM
EJ8 GSR-T
Oct 29, 2006 08:46 AM
InfamousRS
Apr 23, 2002 10:07 AM
gsr98vtec
Jan 19, 2002 09:37 PM
