turbo help
Old Sep 20, 2004 | 05:50 PM
crazyslowhatch's Avatar
Default turbo help
i'm lookin to turbo my minime low budget style, i'v got a few turbos sitting around but they need to be rebuilt. my question is would this turbo (4387235 mitsubishi TE04H) be good to use? only wanna run 8psi max not sure if that matters or not.. i can get pics of the two turbos i have when my brother comes over with his cam.. they both have shaft play and will need to be rebuilt but should i even mess with them or just find a diffrent one?
Old Sep 20, 2004 | 07:20 PM
Default Re: turbo help (crazyslowhatch)
no help guys?
Old Sep 20, 2004 | 07:23 PM
TheShodan's Avatar
Moderator
Get another turbo. This is a waste of time.
Old Sep 20, 2004 | 07:47 PM
Johnyquest's Avatar
Default Re: (TheShodan)
All turbos have shaft play. It is only important if:
1) the blades hit the side of the housing
2) there is signifcant in/out play.
When the turbo's bearings fill with oil, they tighten right up. Many turbos that you would think need a rebuild when on the bench dry still boost just fine w/o blowing oil once they get installed.
Matt
..what you should have gotten out of this, I hope, is that if I were you, I'd try them before I spent money to rebuild them.
Old Sep 20, 2004 | 08:01 PM
Default Re: (Johnyquest)
thanks johnyquest, i'm not very turbo smart but you helped me out.. i kno one of them needs to be rebuilt, when it came off the car it had been leakin oil..
b15ser
May 29, 2010 03:17 AM
o'malley_808
Sep 2, 2005 06:11 AM
h22vtecmonster
Nov 8, 2004 11:37 AM
crazyslowhatch
Sep 20, 2004 05:26 PM
89 CRX SI
Oct 9, 2002 05:35 PM
